Cruise control not working.
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Aug 11, 2020.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    My cruise control on my 2008 Prius doesn't work.
    All the other accessories on the wheel do work including climate control, radio, map ECT.
    This car has never been in an accident also
    What are some trouble shooting steps I could take to find the issue?
  2. gen2pria
    gen2pria Junior Member
    los angeles
    the clock spring is most likely the cause of your control issues.
    edthefox5 likes this.
  3. Banksy
    415
    132
    Are there any lights that are supposed to come on when CC is active? I was thinking it was the switch itself and to just replace that.
    Rather not do the shotgun approach lol. Also which fuse is for the cruise control? Haven't checked those yet
  4. ChapmanF
    18,569
    Do you have access to Techstream? I'm pretty sure you can go to the active Data List and watch the state of the cruise control switch in (near) real time as you move the switch around; that will show you if the signals from the switch are reaching the ECU. Might also show you other possible issues if the ECU has logged them.
  5. Banksy
    415
    132
    I do have techstream actually
    Didn't know it could do this let me check
  6. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    There is a light on the Gen 2 dash that shows Cruise Control is active.
