Cruise control problems
Discussion in 'Prime Technical Discussion' started by Db17, Jan 10, 2017.
  1. Db17
    Db17 Member
    188
    92
    Visalia, CA
    this has happened a couple of times after about an hour of driving where I can no longer set the Cruise control. So I pull over turn off then back on the car and things work as expected. Has anyone else experienced something like this?
    #1 Db17, Jan 10, 2017
    CaliforniaPrius likes this.
  2. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I think this may reference a message within another thread but could you explain what happened? You said this has happened but there is no detail as to what this is. Are you saying cruise is turning off or some other issue?
  3. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    What do you mean "no longer set the cruise control"? Do you mean 1) the cruise control stops functioning as a cruise control by cancelling itself and you end up with driving without it being engaged, or 2) you can't adjust the parameters of the cruise control, ie. top speed, following distance, etc., or 3) after you disengage the cruise control, you can't re-engage it in the way you used to do?
    priuscatprimeguy likes this.
  4. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Sorry, I can't re-engage after stepping on the brake.
    Hitting "resume" does not work. Resetting does not work. Shutting off the cruise control then on will not re-engage. But after I pull over and teen car off then immediately back on everything is back to normal.
    #4 Db17, Jan 10, 2017
  5. CaliforniaPrius
    313
    201
    Alameda, California
    Did you notice if the LED indicator went on when you tried to engage cruise control? How about the central panel? Did the car say anything there?
  6. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    What's the weather condition outside the car? If the windshield where your camera is looking out at is fogged up, it will disengage Cruise Control feature and Lane Departure Alert since the camera is needed for those features to work.
  7. Db17
    Db17 Member
    188
    92
    Visalia, CA
    I think I've figured it out and I'll share because I don't see it called out in the OM.
    If you have the Cruise on and you shift into the B position. The Cruise system will not work until the car has been power cycled. It's also possible that I never shifted back into D.
    Seems to me though, if cruise control cannot operate in B then if you shift there the Cruise icon should disappear from the display
    Between the 2 owner manuals, there are over 1000 pages to read. I think that's a lot to ask for a consumer product.
    #7 Db17, Jan 11, 2017
  8. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    But if you skip all the CYA obsessed warnings, the actual manuals are only about 20 pages.
    ttait likes this.
  9. MattStevenson
    MattStevenson Member
    57
    35
    US
    You shouldn't be using B mode unless going down mountains and you keep fully charging your battery. It's just using the engine as a brake to help slow you.
    Prius Maximus likes this.
  10. Db17
    Db17 Member
    188
    92
    Visalia, CA
    I was going downhill when I used it.
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    That would be a bug you should report to Toyota.
    That would be a "PICNIC" and thus not reportable to Toyota.
    "Dynamic radar cruise control with full-speed range can be set when
    ●The shift position is in D."
  12. James Wells
    James Wells Junior Member
    35
    28
    Austin, TX
    My experience too. Shift back to D, all is good.
