Cruise Control Switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by googer, Sep 5, 2020.
  1. googer
    googer New Member
    Dublin, Ireland
    Business Edition
    Hi
    I am trying to diagnose a faulty cruise control.
    I want to know if it is the control stem or the entire clock spring
    The "on" button to the stem is spongy and does not click. Is this how it is supposed to be?
    Regards
  2. JC91006
    16,825
    8,600
    I don't know if you're suppose to actually hear a "click", but does the cruise control actually work? The clock spring has nothing to do with the feeling of the cruise control button.
  3. googer
    googer New Member
    Dublin, Ireland
    Business Edition
    The cruise control is currently not working and I am trying to rule out the stem or the clock spring.
    If the button is meant to click than I know it's probably that as mine does not!
  4. JC91006
    16,825
    8,600
    The cruise control stalk rarely has any issues. It's more likely to be your clock spring (if it's been replaced with a non OEM part previously). When the clock spring goes bad, normally there would be other buttons on the steering wheel that won't be working properly (like the air recirculation button and volume buttons)
  5. googer
    googer New Member
    Dublin, Ireland
    Business Edition
    Thanks for the reply.
    Yes I figured it was one of those two.
    I am happy to replace the clock spring if needed. I just would like someone with a gen 2 Prius with cruise control to confirm there is no click with the on button.
    So like a light switch not an elevator button.
    Thank you
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Before you get too carried away......check the brake lights to be sure that that brake switch is not stuck ON.
  7. dolj
    dolj Senior Member
    8,547
    4,341
    Wellington, New Zealand
    No, it doesn't click. It just presses in and toggles the Cruise Control on and off. Your description of "spongey" sounds about right.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Its a very definitive mechanical click when you push it in not spongy at all. You can hear it click when you push it in.
    If all the radio button and cd buttons and all the ac buttons work on the steering wheel work its probably not the clock spring.
  9. ChapmanF
    18,492
    Mine does not click. It has kind of the feel of a rubber membrane bubble button, as so many things do nowadays, like the keys on this keyboard ... not clicky really, but with a subtle sort of pop that you feel on the way down and the way back up.
    My experience with things with membrane switches when they stop working isn't very encouraging for trying to judge by the feel; in most cases I've known, they still have the poppy feel, they just don't work anyway.
    If you have access to Techstream, I believe you can watch the switch inputs to the ECU as you press the button, move the stalk up and down and toward you, and see which signals are getting through, if any.
    #9 ChapmanF, Sep 7, 2020
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Doesn't work like that on mine at all.
    No click on any Toyota I've ever owned, about 6 of them.
  11. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Sorry let me reword that there is not a latching click per say as it does not latch it’s a momentary switch but when you push it it’s a nice clean mechanical click to it not spongy at all.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    YOURS does that. MINE does not.
    At 13 years old, maybe yours is wearing out.
    Or maybe the design has change slightly over the years.
    I just went out and tested mine.
    No click......unless you stab it REAL hard.
  13. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Have never used mine once in 13 years of ownership.
    Do you even own a g2?
    Raytheeagle likes this.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Nope, but he's seen one:cool:.
    They must all be the same:whistle:.
    The ignore user function is a good one(y).
    mjoo likes this.
  15. dolj
    dolj Senior Member
    8,547
    4,341
    Mine is the same as described by ChapmanF and like SS2 I have driven other models of Toyota with CC and the stalk and switch seem identical, right down to the tactile feel. Maybe Ray's is just like new seeing as he says it's never been used in 13 years.
  16. googer
    googer New Member
    Dublin, Ireland
    Business Edition
    Firstly thanks for the replies
    I think it is the clock spring. The cruise starts working when I rotate the wheel all the way to left. And then the air recirculation stops!
    Pretty conclusive.
    ChrisFix has a handy youtube video on the fix so I will give it a go the weekend.
    Fun times.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Wasn't Ray who said that but Ed.
    Are they the same person ? :ROFLMAO:
  18. dolj
    dolj Senior Member
    8,547
    4,341
    Yes, one and the same.
  19. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Ed is a Ray, just not me;).
    But who am I:whistle:?
    Just another guy on the internet (y).
    dolj likes this.
