cruise control
Discussion in 'Gen 3 Prius Main Forum' started by Princedunet, Feb 3, 2016.
  1. Princedunet
    Princedunet Junior Member
    46
    morocco
    2012 Aqua
    Hello everybody
    Im asking if there is an option to determinate a speed to do not exceed, like a speed limiter and not a fixed speed
    #1 Princedunet, Feb 3, 2016
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Welcome to PriusChat! …and to answer your question, I find the posted speed signs (written in large, friendly black numbers on white signs by the side of the road) as a perfectly adequate guide… ;)
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I suspect there are fewer.signs in Morocco.
    So far as I know, there is no upper limit for cruise control.
  4. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    In Italy those signs appear to indicate the minimum speed.
  5. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    I think the OP is asking whether the Prius has a speed limit warning that will sound a tone when you exceed some user-selectable speed. BMW has this feature, but I'm pretty sure Prius does not.
  6. tv4fish
    tv4fish Member
    202
    46
    And, I think he wants to know what is the maximum speed before he might do damage to his engine................
  7. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    certain mercedes models have a speed limiter/
    you set it to whatever speed & even with pedal to the medal you're unable to go over the set speed/
    edit: just found this here:
  8. Princedunet
    46
    morocco
    2012 Aqua
    thanks everybody, but seems it doesnt come with the prius
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Surprised to hear that ANY vehicle has this feature.
    You'd think manufacturers would avoid it simply as a safety issue. As you really never know when you might NEED sudden speed.
    No, as far as I know Cruise Control....on a Prius is "cruise" control...that is setting a fixed "cruising" speed. One in which you have the instantaneous option to exceed or slow down from.
  10. Princedunet
    46
    morocco
    2012 Aqua
    of sure not any vehicule has this feature but Prius has many hight options and this one is missing and i dont know why realy because is very usefull
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Think "Church Van", you don't know who may be driving it, but you want to have some control over how they drive it. Max Speed Limit +1 will look good as a limit.
  12. Princedunet
    46
    morocco
    2012 Aqua
    Max speed limit isnt like a limit because when you just press gas or brake pedal you lose determination and you have to set it again,
