Cruise Control
Discussion in 'Gen 2 Prius Main Forum' started by Xsparks, Oct 29, 2004.
  1. Xsparks
    Xsparks New Member
    Whenever I stop at a light and then continue, and hit resume on the CC nothing happens and I have to reset it. This doesn't seem right.
    Great web site. It helped in my decision to buy a Prius.
    Brian
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Sadly it is working as designed. It isn't my favorite feature. I guess it is supposed to make sure you don't come off the interstate, then 'resume' on a 35 mph road or something. It is annoying when you are travelling on a road with a constant speed and some number of traffic controls spaced such that using CC is a reasonable thing.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yup, as designed. I much prefer the CC in my Ford vehicles. With time using the Toyota CC becomes pretty automatic, but it's still not the best.
  4. Xsparks
    Xsparks New Member
    I've never owned a Toyota before. I wonder if they are all like that.
    Also there is no auto on - auto off feature. There is a place on the top of the dash for the sensors and its in the manual. All specs I have ever read say auto off, which is what I have.
    Brian
  5. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    Each of the Toyota's I owned with CC ('82 Celica, '88 & '00 Camry, '04 Prius) did the same.
  6. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I've found that as long as you stay above 25 or so, it'll resume.
  7. forte88
    forte88 Member
    143
    44
    Socal
    According to the Prius Users Guide: "Slowing down below 24 MPH (39 km/h) will cause the memory to reset. So if you have to slow down or stop, you'll need to set the speed again rather than using the resume feature."
  8. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    It's annoying. I don't even use the "resume feature" in the Prius. All of the other cruise controls that I've had, remember their set speed untill the vehicle or unit is shut off - even the one on the motorcycle. I guess every automaker has to have a quirk, and this is Toyota's.
