Cruise control
Discussion in 'Gen 2 Prius Main Forum' started by jo, May 2, 2005.
  1. jo
    jo Junior Member
    Henderson Harbor NY
    I'm used to cruise control on previous non Prius cars, but on my Prius, i can't seem to get resume to work........is it me, is it not working right and I need to get it looked at, or is it how it is supposed to work? I can only get it to work if I slow down just a bit (maybe 5 mph) and then push the lever up :roll:
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    isn't resume pulling back?
  3. jo
    jo Junior Member
    Henderson Harbor NY
    Hi
    yes, it does pull back, but the spped doesn't resume to where i had it set.
  4. Tideland Prius
    16,161
    Pulling back is Cancel.
    The Resume function won't work if you drop below 25mph / 40kph or drop 10mph / 16kph below the preset speed.
  5. V8Cobrakid
    3,790
    152
    strange... :? strange...
  6. jo
    jo Junior Member
    Henderson Harbor NY
    Thanks, Tideland Prius..........it isn't me, then, and it ain't broke.........I can live with it :D
  7. Tideland Prius
    16,161
    okay then. Glad to know it's a-okay
  8. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"86610)</div>
    Yes, I believe you can drop below 10MPH from preset and resume. I've resumed just at 25 or so MPH when preset was 45 or better. it seemed like it wasn't working, as CC takes a few seconds to decide on its attack of acceleration to preset speed.
    I believe what you are thinking is that CC will cancel if the actual vehicle speed drops below 10MPH from where it thinks it should be. In other words, it is trying to maintain 45, but stuck brakes cause the car to slow to 33MPH, CC will disengage.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(jo\";p=\"86600)</div>
    There are several different 'designs'. The Prius works exactly the same as my wife's Subaru. My prior vehicle ('95 Odyssey) would allow CC at 25 and over and NEVER dropped the preset unless you turned the car off or turned off the master switch. I much preferred that design. But for actual FUNCTION I prefer the Prius CC, it engages very predictably and a single bump up or down will give you exactly a 1 MPH change.
  10. Tideland Prius
    16,161
    <div class='quotetop'>QUOTE(DanMan32\";p=\"86730)</div>
    [/b][/quote]
    See Dan, that's the problem with the manual lol. Thanks for clarifying that!
  11. DanMan32
    3,799
    26
    Tampa Bay, FL
    Just in case, I did confirm that you can resume if your current speed is more than 10MPH from preset. I was able to resume to 45MPH after dropping down to 30MPH.
  12. Tideland Prius
    16,161
    Alright, thanks Dan.
