Cruising Mileage Indicator Issue ?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TruSound, Oct 20, 2015.
  1. TruSound
    TruSound Member
    246
    32
    The 818
    OK gang here's the deal and it's driving me nuts.
    Up until about a month ago my cruising mileage total number after fill up would vary between 390-430 miles depending on how much I topped off the tank, over the last 6 weeks or so the number never exceeds 379 even after filling it to the point of overflow.
    When I bought the car it came topped off from the dealer and the total cruising range indicated more than 450 miles, 459 is actually the number I remember, does anyone have any idea what's going on here ?
    Thanks all
  2. Air_Boss
    Air_Boss Senior Member
    4,007
    1,099
    New Yawk
    Endurance is based on recent average mpg times tank quantity. Has your recent average mpg gone down?
  3. dorunron
    dorunron Senior Member
    3,318
    1,104
    Houston, TX
    If you are doing a LOT of high speed driving, it is understandable why your range is as low as it is.
    IMO, it is not a good idea to top of the tank either.
    The above is my opinion and or my two cents worth, whatever that is.
    I wish you the best of luck. I do believe if you will slow down your range and MPG will improve.
  4. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    When you bought it did it have big wheels and non LRR tires or did you add these: Motegi Racing 17x7 MR121 wheels, Michelin 215/50/17 MXM4 Primacy
    As the car learns from past tanks, choices you make will be reflected.
  5. Mendel Leisk
    39,015
    To paraphrase Bob Dylan: "I wouldn't pay it any mind".
    Really, fugedabout miles-to-empty, focus on mpg.
    m.wynn and CR94 like this.
  6. TruSound
    TruSound Member
    246
    32
    The 818
    My bad gang, my wife drove my car all summer with the AC on all the time, I never use it...mileage is fine, just checked it the old fashion way, 52mpg.
    I now run with trip meter reset after fill up and have turned off all computer mileage data info. Thanks for all the feedback.
