Cruising Range City poor?
Discussion in 'Gen 3 Prius Fuel Economy' started by Calirrm, Oct 20, 2023.
  1. Calirrm
    Calirrm New Member
    LA
    2014 Prius Four
    Tires 215/45ZR17
    138,000 miles on it.
    Currently using this vehicle for rideshare and food delivery, so lots of stop and go.
    The cruising range city after pump the gas is about 416 miles wich means about 35 MPG.
    For those who have this vehicle, can I improve the MPG or it is just the vehicle aging?
  2. fuzzy1
    10,149
    How do you figure that?
    Don't assume that is figured with the claimed fuel tank capacity, because it isn't. Several gallons are set aside as safety margin, and not counted towards the displayed range. To get a "distance to empty" of 416 miles, its recent history must be getting over 40 mpg.
    The true way to compute MPG is to compute it from fuel refills. Keep a fuel / odometer log.
    Short of that, use the trip odometer MPG display, and remember that it is a bit "optimistic". E.g. subtract 5%, give or take several %.
    If this car is new to you, skim through this post for ideas:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    Beware that that post was written for new drivers of new cars, so doesn't cover old-car problems such as dragging brake pads and many others.
    #2 fuzzy1, Oct 20, 2023
    Calirrm likes this.
  3. Calirrm
    Calirrm New Member
    LA
    Thank you.
    Yep, I just mention the dash info after pump the gas. I was also looking for any thoughts about how to improve the MPG based on the current vehicle tires and city food delivering.
  4. fuzzy1
    10,149
    Notice that I added a link to a fuel economy page after you first read it.
    Calirrm likes this.
  5. bisco
    49,371
    well, if you're getting good mileage, there may not be much more you can do.
    one major item on gen 3 is the egr circuit
    Calirrm likes this.
  6. V Sport Wagon
    V Sport Wagon Member
    227
    83
    It's dead, you should sell it to me for cheap...(y) jk! Maybe air up tires, check the HV battery health with the Dr. Prius life expectancy test and go from there. Also always drive far enough to warm up the engine fully and no short trips if possible.
    Calirrm likes this.
  7. ttou68
    ttou68 Active Member
    345
    203
    Try cleaning EGR circuit and intake manifold..
    Helped some friends's interstate fuel economy from 38 to 47
    Calirrm likes this.
  8. Mendel Leisk
    38,643
    17” tires and “lots of stop and go” both likely factors.
    This is calculated mpg?
    I second the EGR cleaning, not so much for mpg, but for engine preservation. It’s overdue. See first two links in my signature (on a phone turn it landscape to see signature).
    Calirrm likes this.
  9. Tideland Prius
    16,125
    *Threads merged*
