crunch-like gear noise when driving on uneven sandy/dirt roads
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by chinarut, Jun 30, 2023.
  1. chinarut
    chinarut Junior Member
    2019 Prius
    we have few unpaved roads in this part of town and occasionally when the road gets uneven, I slow down to less than 5 mph and sometimes hit a really sandy part of the road. then I hear a loud "crunch" like noise - I'm no expert but I'm guessing its the differential shifting power to the other front wheel?
    Just wanted to know if this is normal (as it's pretty loud (but brief)) and if anyone else has run into this issue?
    It's happened 3 times in the last 9 months and always the same circumstance with one wheel in the sand or really loose dirt (or mud) trying to get traction.
  2. FuelMiser
    FuelMiser Senior Member
    1,303
    890
    Monument, CO
    You could be activating (causing to activate) the Traction Control, which will briefly reduce power to the drive wheels to stop the slipping, light up a yellow caution on the dash and yes, make some odd noise in the drivetrain. You should also feel some pulsing in the accelerator pedal. I'm not sure about shifting power from one drive wheel to another, but it could be.
  3. Leadfoot J. McCoalroller
    7,237
    6,784
    Pennsylvania
    2018 Prius c
    A differential can and should shift power almost silently.
    From your description, I wonder if you are sinking somewhat in the soft sand and just bottoming out, scraping the belly of the car.
    That makes a wonderfully loud crunch.
    Doug McC likes this.
    49,693
    Or the suspension needs work
  5. chinarut
    2019 Prius
    hey thanks everyone for the replies!
    I had this happen in the rain once and do remember the light coming on along with some noises. This other sound is more of a "gear slip" kind of noise (almost like it's skipping a tooth - at least this is how it sounds to me)
    Scraping the belly of the car does indeed make a bit of a ruckus! the times this has happened, the sound is distinctly more "scrapey" and plastic-like. I'm also quite certain it's not bottoming out - I've bottomed out a 1 or 2 times with a more a low-pitched, dead "thunk" sound resonating from the car body itself.
    The sound I'm speaking to is more high-pitched "clacky" sounding for a split second.
    I've got a webcam, I'll re-enable audio recording again & post though I certainly don't wish it to happen again :)
