Crunchy Sound When Coming to a Full Stop
Discussion in 'Prime Main Forum (2017-2022)' started by geguia, Jun 18, 2018.
  1. geguia
    geguia Active Member
    209
    108
    los angeles
    Anyone experience this crunchy sound when coming to a full stop - not a hard stop but a light slow stop?
    I'll be taking the car in of course. I can't imagine the suspension failing so soon but never know.
    It kind of reminds me of an old leaf spring not quite 'springing' back if that makes any sense.
    49,397
    is this your first prius?
  3. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I hear a clunking noise once in a while when coming to a stop. I have seen other threads here discussing similar items. My theory is one of two items or both. To reduce drag on the calipers, they are made to completely release from the disk and not rest against the disk. The clunky sound is when they actually engage against the disk. Or it could be something to do with the DC charging apparatus on the wheels engaging or disengaging.
  4. Holobowicz
    Holobowicz New Member
    Moncks Corner, SC
    I had a clunking sound and ended up having to take my Prius in and having bolts put in my rear suspension because they had loosened to the point of almost falling off! Glad it wasn't something dangerous, rear suspension malfunction I can handle with a few cuss words but front suspension nope.
  5. bisco
    49,397
    there is no charging apparatus on the wheels, it is all in the tranny. could be the brake pads, they move back and forth a bit with forward and reverse.
    Dudley1030 likes this.
  6. Dudley1030
    200
    139
    Lawrence, KS
    good to know. I never knew where it charged from. I think the salesman said "everything that turns charges the battery". LOL never trust 'em!
  7. bisco
    49,397
  8. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I think its the brake regen system
  9. Trollbait
    11,514
    My 2013 Sonic had springs that would push the pads a away from the rotor after releasing the pedal. Such systems are likely common on all cars now.
  10. breakfast
    breakfast Active Member
    266
    199
    Most likely it's totally normal - it may be your brake pads against a rough disc surface. The friction brakes often don't get used at all for a long time on a Prius (because the "regenerative brakes" are your electric motors turning in reverse to slow the car and charge your batteries), but they are needed to get from a very slow speed (8 MPH in the Gen 3, even slower in the Prime) to a complete stop. It's SoCal so you don't get much rain... but is the sound worse after it rains?
  11. bisco
    49,397
    maybe test drive another at the dealer.
  12. bresna
    bresna Active Member
    193
    144
    Southern Maine
    You could be hearing the mechanical brakes finally kicking in - they don't kick in until you get below 5 mph. You could also be hearing the noise maker. When you're in electric mode below a certain speed, there's a noise maker that some say sounds like growl or rocks rolling around in a can. I can't hear it. Maybe yours is louder than others?
  13. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If you washed the car and left it overnight the brake disks rust a bit. If you then drive it "gently" the friction brakes are only applied for the last second or two of stopping. It sounds "crunchy" or like sandpaper rubbing. Only lasts a few miles. I found it amazing how much stopping power regen has (when the car was not making the "crunchy" sound).
    You can confirm it is the rust by stopping hard a few times, then seeing if the sound is gone.
  14. Trollbait
    11,514
    Rust on the rotor is a likely culprit, but it should disappear after a hard stop or two that go right to friction braking. The rust is usually visible on the rotor through the wheel spokes.
