cruse control only works when it feels like it
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob Holliston, Apr 17, 2019.
  1. Bob Holliston
    Bob Holliston Junior Member
    31
    Sometimes the C/C works...…. sometimes it doesn't. Also, the keys (2) don't work unless I put them in the ignition, new batteries in both. Lock/unlock buttons don't work either.
    51,155
    12v health?
    test the clock spring by trying the horn in all wheel positions
    SFO likes this.
  3. 2009touring
    2009touring Junior Member
    Had an issue with my 09 but mine where it would disengage with a slight bump. Turned out to be the brake light switch by the pedal.
    R-P and SFO like this.
  4. Tynyyn
    Tynyyn Member
    108
    29
    Bella Vista Arkansas
    Either a clock spring or a brake light switch. You might want to do a search on the recall for brake light switch from Toyota. Try that first before you crack into the steering wheel.
    If you gotta get a clock spring the best price will be from Amazon but it will come from China and will take about three weeks to get to the States. A brake light switch is available from any local parts store, but it is pricy. Pulling the trim skirt from around the bottom of the steering wheel is a must unless you have the arms and fingers of a five year old.
    I just replace the brake light switch on my Prius in order to cure my wonky CC. Just my two cents, but I'd give the brake light switch a go, first before you test the waters of the clock spring.
    Hope this helps.
  5. R-P
    R-P Active Member
    804
    288
    Netherlands
    I stlll wanted to check all connectors between ABS sensors and ECU. Never figured it might be something so simple... Been having trouble for years.
    So there has been a recall? I'll phone my dealer to check.
    I have asked about it at their service desk but they played dumb (the slight-bump=CC disengage, not the brakelightswitch)
