cruse control quirks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, Apr 8, 2015.
  1. Former Member 68813
    3,524
    981
    US
    i just came back from a long road trip in hilly terrain and noticed the speeds while on CC were +/- 1 mph all the time and even sometimes +/- 2 mph. this creates a problem when you are near cars that keep similar but constant speed on CC. whats even weirder is the higher speeds were typically near the top of uphill and lower speeds were sometimes downhill. what gives?
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    If +/- 2 MPH gets you too close to other cars........you were too close to them in the first place. :)
    Seriously.
    Does your model have an ECO button?
    Maybe it would maintain the speed better with ECO off ??
    I haven't tried my C to see.
  3. fuzzy1
    10,167
    Are you in ECO mode? If so, turn that off and go back to Normal, which has tighter speed control.
  4. Former Member 68813
    3,524
    981
    US
    nice try, i never use ECO mode.
  5. bisco
    49,469
    i've never had any luck with any of our hybrids holding a constant speed on hilly terrain.
  6. Easy Rider 2
    1,584
    257
    Ocala, FL
    Well then we are back to this:
  7. Mendel Leisk
    38,717
    First world problems. ;)
    Former Member 68813 and fuzzy1 like this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Plus or Minus 1 or at most 2 mph on hilly terrain?
    And this is a problem....why?
    Cruise Control isn't magic, it still is just a machine working against the forces of gravity and momentum. Cruise control cannot see or pre-compensate for changing inclines, why would you expect it to be able to keep the perfectly constant given those parameters.
    I've never owned a vehicle with cruise control that COULD keep the speed perfectly constant all the time especially up and down hilly terrains.
    My advice would be when going up and down hilly terrain? Just look at the road ahead....keep your eyes off the speedometer. You'll never even notice that you momentarily lost or gained a single MPH or two.
    I
    DoubleDAZ likes this.
  9. bisco
    49,469
    sometimes i wonder if the cruise is working on the guy i'm catching up to.
  10. fuzzy1
    10,167
    I think that point is that he wouldn't notice, if not for the cars near him that are also using CC.
  11. The Electric Me
    9,083
    5,798
    Again what are your expectations?
    Up and Down Hills or perfectly flat terrain, I don't expect cruise control to be a complete "Auto Pilot".
    You can set CC on an "Autobahn" stretch of highway, and still come up on other vehicles that are going slower, faster and may or may not be using cruise control themselves.
    Bottom line, I don't think 1-2 mph fluctuations in speed, especially while going up and down hills, is a problem at all.
  12. Former Member 68813
    3,524
    981
    US
    exactly. besides, the hills were not even steep, just the regular rolling hill variety.
  13. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Every car with CC I've had works pretty much the same way. The Prius might be a little less sensitive to gradual inclines than some heavier cars, but your description seems reasonable. The Prius does seem to do the +1/+2 nearer the top of a hill more than I remember with our old van, but nothing problematic.
  14. fuzzy1
    10,167
    Over five different models on four different brands, I've seen a fairly noticeable difference among CC systems. The Prius in ECO (I don't use the other modes) has a wider variance than average, but I don't think think it is as wide as my long gone '84 Ford 2.3L.
  15. qdllc
    qdllc Senior Member
    1,370
    399
    My CC works as well as I've seen CC work on any vehicle. :barefoot:
  16. mrbigh
    3,686
    699
    Long Island, NY
    I adhere to the majority of comments, my CC works basically the same; +1MPH is a normal gauge but, I do not have hill conditions to test; we are flatlanders around here.
  17. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    If it's a problem, upgrade to the Five with DRCC. The speed will still vary a little bit, but you'll never get too close to anybody else because of it. :D
  18. qdllc
    qdllc Senior Member
    1,370
    399
    If anything, the Prius CC is supreior.
    Normal CC units will aggressively add gas when the speed drops 2 mph below the set speed (going up hills). The Prius does the same.
    Normal CC units simply coast when going downhill, regardless of speed gain. The Prius will engage regenerative braking to resist excess coasting. Until your battery maxes out, you have the car trying to slow you down to the set speed without using the brakes. To my knowledge, modern CC units don't do this on other cars.
  19. breakfast
    breakfast Active Member
    266
    199
    The Prius has a significant edge with regenerative braking, but there are other cars (including my Honda...) that use a combination of engine braking and transmission downshifts (using the transmission's grade logic) to maintain the set speed on downgrades.
  20. Easy Rider 2
    1,584
    257
    Ocala, FL
    Sure they do. It is called compression braking.
    It is not as pronounced as the regen action but just about as effective.
