CT200H - change backup beep
Discussion in 'Lexus Hybrids and EVs' started by lamontcranston, Mar 9, 2011.
  1. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    Hi all,
    it seems that the CT200H suffers from the same backup beep as the Prius and Lexus HS. Do you all know if it's possible to change it to a single beep? Any advice if the dealer says it's not possible?
    Thanks!
  2. porttac
    porttac Member
    114
    39
    port townsend,wa.
    I wonder if the delete sequence is the same as in the Prius?
  3. lamontcranston
    212
    17
    Southern California
    Well I tried the 2004-2009 sequence just for yucks, it didn't do anything.
  4. porttac
    porttac Member
    114
    39
    port townsend,wa.
    yah, I just read that in the Gen3 Prius, Toyota made it impossible to delete the back up beep....must be the same in the CT.
    crap.
  5. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Seach this forum for Scan Guage codes, there is a code that can be entered in the scan gauge that will change the constant beep to a single beep on the Prious. I don't know if the same code will work on the CT. You can also have the dealer change it at your first service or before you take delivery.
  6. lamontcranston
    212
    17
    Southern California
    I bet it will. The CT200h is an awful lot like the Prius in so many little ways and I bet a lot of the software is the same.
  7. Tideland Prius
    16,016
    You can reduce the beep to a single beep when Reverse is selected on the Gen 3. It's dealer-customisable and found on the appropriate section in the Owner's Manual.
  8. dgstan
    dgstan Member
    159
    OC
    BTW - I believe it's page 702 of the owner's manual where it lists the options for the reverse and seatbelt beep. If the dealer balks at changing it, show them that it's listed as a dealer customizable option.
  9. dgstan
    dgstan Member
    159
    OC
    I have spoken with the service manager where I bought my CT. Next time I bring it in, they have agreed to turn off the incessant reverse and seat belt buzzers.
  10. GaryN
    GaryN New Member
    Wisconsin
    Go to the Lexus main site and navigate to the CT200h page. From there choose 'service & maintenance' from the 'Features and Pricing' menu. Once there, choose the 'Service' tab and select 'Lexus Personalized Settings'. A list of PDFs for specific vehicles will appear. Choose your model to download its PDF. The single beep option is shown last (#36) - a dealer-only change. If the dealer says it's not possible, show him your printout. Hope this helps.
