Cup Holders
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mwhaley99, Jun 20, 2006.
  1. mwhaley99
    mwhaley99 New Member
    63
    The cup holders suck in the prius.
    One is square shaped and the 2nd one is just too damn wide.
    Most of my normal cups/travel mugs etc move around a lot and some even tip over and fall out when they are nearly empty.
    Does anyone have any ideas on how I can make them fit better ?
  2. Jim1eye
    Jim1eye Shaklee Ind Distributor
    181
    Connecticut
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Mark Whaley @ Jun 20 2006, 03:24 PM) [snapback]274203[/snapback]</div>
    Styrofoam works. I made a nice little tray for the under-console draw. Got tired of everything rattling around in there.
  3. HokieHybrid
    HokieHybrid New Member
    200
    I often use the ones for the rear seats for actual drinks instead of the front two. (Flip down the back of the console...if you haven't found these yet.)
  4. brandon
    brandon Member
    771
    Manhattan, KS
    <div class='quotetop'>QUOTE(Mark Whaley @ Jun 20 2006, 02:24 PM) [snapback]274203[/snapback]</div>
    Maybe I've not been paying close enough attention, but I could've sworn my cupholders are all round as opposed to square... They all fit a cylinder, anyway.
    lol! I must confess, they fit my 32-ounce soft drinks perfectly! When all else fails, try upgrading to a larger drink :)
    Then again, drinking 32 ounces of coffee while driving could be a bit dangerous...
  5. GasGuzzler87
    GasGuzzler87 New Member
    131
    at least you HAVE cup holders. When I drive thougfh, I turn to my cup holder and ask it what it wants to eat (passenger)
  6. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(GasGuzzler87 @ Jun 20 2006, 03:25 PM) [snapback]274324[/snapback]</div>
    Same here, my last car didn't have any cup holders, so anything is an improvement. It fits one of my travel mugs, so that's the mug I use. Plus it holds sodas (either can or cup).
  7. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    <div class='quotetop'>QUOTE(aaf709 @ Jun 20 2006, 03:34 PM) [snapback]274332[/snapback]</div>
    Cars without cup holders!!! Shirley you jest!!
    We have become such a spoiled group, heated seats, heated steering wheels. Anybody riding antique autos??
    I haven't had any trouble with the cup holders except for the fact that they are front to back. I don't have company that often so I am usually like "were you front and I was back or the other way?? Side by side was easier to keep track.
  8. withersea
    withersea DNF is better than DNS
    1,162
    TN
    I'm looking forward to my Prius cup holders. I drive a Honda CRV now. The CRV HAS to take the award for the worst cup holders in history. Take a curve at almost any speed and your cup flies across the car and out of reach or under your feet along with what was in it.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Try using different cups. Our last car had cup holders that fit ceramic coffee cups perfectly, but anything else tipped over on the first turn. The Prius works better with travel mugs, cans, and bottles, but not ceramic coffee cups. Our solution was to buy some travel mugs that fit well and use these.
    Tom
  10. Lil Mo
    Lil Mo New Member
    171
    <div class='quotetop'>QUOTE(qbee42 @ Jun 20 2006, 07:47 PM) [snapback]274482[/snapback]</div>
    Sometimes it is the obvious answer that works the best. :)
  11. ghostofjk
    ghostofjk New Member
    979
    You could rubber band a few thicknesses of handkerchief (or any rag/cloth) around the bottom of your cup.
    I went to about a dozen stores looking for a thermal container the bottom of which fit closely.
  12. cmwade77
    cmwade77 New Member
    116
    The only problem I have ever had is with too alrge of cups, but then again i do live in California where every drink is huge! LOL, not really, I have had everything from travel mugs to small drinks, everything fits fine, except Del Taco's XL Fiesta Cup at the moment, it only fits in the back cup holder, not the front one. I find the square shape comes in handy from time to time, if I have and odd shapped item, i.e. I bought my Fiancee flowers once and used it to hold the vase, it worked great!
  13. Tideland Prius
    16,155
    <div class='quotetop'>QUOTE(brandon @ Jun 20 2006, 03:01 PM) [snapback]274306[/snapback]</div>
    Take a close look at the forward most cupholder. That's the one that can fit square items.
  14. Catskillguy
    Catskillguy New Member
    536
    Mid Hudson Valley NY
    My 2 cents
    I have found them to be fine for most any purchased coffee, water, etc (except one very portly 1 liter bottle of spring water (Saratoga Water). In fact, the first month or so I refused to bring anything BUT water into the car!
    My old car, the cup holder broke 2 winters ago. It had these foam rubber tabs that secured the cup tight as you put it through the hole. Well, it was sooooo cold one day , I think it was 15 below 0, (Farenheit for our Canadian readers), and I forced the cup down & it snapped off one of the foam/rubber tabs. After that, the only way I could keep a cup was to stuff a bunch of napkins on the side of the cup.
  15. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Glue in chunks of foam?
    My ol' Subie also had a spring-loaded tab in the center-console
    cupholder, presumably to take up the slack from a small container.
    _H*
