Curious behavior of the ICE - just checking!
Discussion in 'Gen 2 Prius Main Forum' started by pt95148, Dec 9, 2008.
  1. pt95148
    pt95148 New Member
    39
    SJ
    On my regular commute to work, all in town with stop/start traffic, I can usually glide for a couple of blocks. At one stop today, having glided and with the battery at full charge, all the way to the top, I noticed that the ICE kept running. Outside temp was 48F, inside set at 73F, it was early morning and I was warming the cabin temp. When I decreased the temp to 71F, the ICE stopped. When I switched on the windscreen defrost, the ICE started. I switched it off, the ICE stopped. I tried this several times whilst still at stop and the battery showing full charge.
    Then I proceeded along my way, at another stop, this time the battery was down a couple of bars, I tried it again, increase cabin temp, windscreen defrost on/off but nothing, nada, the ICE stays quiet.
    Is this normal? Anyone experienced this? Any explanation on this behavior?
    TIA
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Completely normal. The ICE provides almost all of the heat for cabin heating and defrost, so it runs more in cold weather. There are two small electric heaters that also help.
    Tom
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    just for re-assurance yes it is normal. Commonly I will start my day with heater completely off for the first 5 minutes so the ICE warms up quicker (even the non hybrid car). If I do have the heater on I will turn it off at stop lights if its still warming up so that the engine will shut off.
    Just to add about how the ICE provides heat because I am under the impression that you think the heat in a car comes from electricity. Most cars including the Prius use the warmed up Coolant / Anti-Freeze from inside the engine, The engine starts to get hot and the coolant keeps it at a regulated temperature, the coolant circulates into the heater core the heater core gets hot from the coolant and then outside air through the ventilation system passes through it and picks up heat.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    As posted above, perfectly normal.
    Before Prius is fully warmed up, you can have the coolant drop below about 63C while waiting at a light. If the A/C is calling for heat, the engine will start.
    Your interior temp sensor may have been just at your set temp so when you dropped it a degree it allowed the engine to shut down. Note that the -actual- interior temp is not necessarily the same as the sensor temp. ;)
    Once you get the engine coolant above about 62C - and - exceed about 40 MPH, you get into "stage 4". This allows the engine to shut down if "not needed". It will also shut down at stops earlier in the warmup cycle, just not when moving.
    Note that for awhile after getting the coolant to 62C it will still drop quickly when stopped, as the parts are still not fully warmed up, and during this time the engine may start at lights. It takes about 20 min of city driving to get Prius fully warmed up. It WILL blow nice hot air after only a few minutes, however.
    I shut off the A/C auto function using the steering wheel switch during warmup when stopped at lights to keep the engine off while waiting.
  5. pt95148
    pt95148 New Member
    39
    SJ
    Thank you to all who have replied.
    It makes sense now, especially as I noted that the behavior did not replicate after a few more stops because everything is fully warmed up, even though the battery is down a couple bars.
    I did make a mistake thinking why the ICE did not start under AC condition.
    Thanks
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Sounds totally normal. Try selecting the off fan position (no need to muck w/defrost). The ICE will probably also stop.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Just turn off the climate control with the button on the steering wheel while stopped.
  8. David Beale
    5,963
    1,989
    Edmonton Alberta
    We're all complaining about how cold it is, how icy it is, and how difficult it is driving in deep snow, while Pat is sitting in his car sweating, waiting for the A/C to bring the thing to a reasonable cabin temp. ;)
