curious scangauge behavior
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Nov 28, 2012.
  1. ChapmanF
    17,326
    I started up my car this morning and, while idling in my driveway, stationary, I noticed the ScanGauge reading 9999 MPG. That didn't make much sense, so I switched that pane to display GPH, and sure enough, that was reading zero. The other three panes made sense: RPM (about 1300), LOD (about 40%), WT (about 10 C and climbing). The engine was definitely running, warming up, and using fuel, but GPH was shown as zero.
    I pulled out into the street and on heavier acceleration. the GPH reading actually moved from zero (but to a value lower than I'd expect). But as soon as I backed off on the gas (engine still running, not yet warm enough to shut off), the GPH reading was zero again.
    I unplugged the cable at the back of the ScanGauge, waited a few seconds, and plugged it back in, and it went through reconnection and then all the readings made sense again.
    Has anybody else seen anything like this?
    -Chap
  2. bwilson4web
    16,010
    Interesting. You might check the release version as I know they've made changes over the years. The sad thing is you have to send it back which usually takes a week. There may be a $25 shipping charge.
    GOOD LUCK!
  3. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
    I had an odd situation just the other day myself. Never saw the error again. I had @ & and other weird symbols on everything. When I got home I shut off the car and then restarted the vehicle. No issues and never seen it again. I don't worry about it any more, but it did make my heart drop that it was broke! I would miss my scan gauge or Prius for that matter!
