Current Events
Discussion in 'Prime Plug-in Charging' started by Old Bear, Apr 21, 2018.
  1. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I was curious about how much current the Prime draws when plugged into a Level 2 EVSE unit and running its heat pump in "pre-conditioning mode."
    Using a Leviton model EVR-40 with a kWh meter at the panel. I took these photos this morning because I was curious to learn how much power the heat pump uses:
    The top measurement shows that the electronics in the EVSE use about 3.6 watts. That appears to be the "vampire load" of the EVSE's electronics and holds true whether the EVSE is unplugged from the vehicle or plugged into the fully-charged vehicle.
    When "pre-conditioning" was started, the load increased to 7.5 watts. And when charging, the load shoots up to 3582 watts!
    I noticed, however, that the meter display of watts is inconsistent with its display of current (amps). Simple multiplication of 245 volts x .05 amps is 12.25 watts, not 3.6 watts as displayed. Similarly, 246 volts x 0.65 amps is 160 watts, not 7.5 watts as displayed.
    Full charging mode is more consistent, showing 243 volts x 15.29 amps = 3864 watts which is within 5% of the 3682 watts displayed.
    Even allowing for meter inaccuracy, the low pre-conditioning power consumption is pretty remarkable. I'm just not sure it's believable.
    Now, admittedly, the ambient temperature was 58-degrees F at the time I took these measurements. But the Prime's climate-control cabin temperature was set to 72-degrees so the heat-pump was working to compensate for a 14-degree demand gradient.
    I don't know enough about the design of heat-pumps to know whether the heat-pump would draw more current when the ambient temperature is lower. Or whether the power consumption is the same when running in cooling mode.
    It would be interesting to have more accurate numbers so that I could get a reasonable sense of how many kWh the heat-pump uses while driving -- and therefore how much of the Prime's available battery charge it is using.
  2. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    It would seem that the heat pump is primarily running off of the traction battery, even when the vehicle is plugged in.
    You left one scenario out - Charging with pre-conditioning enabled. Can you post a photo of that?
  3. CharlesH
    2,796
    1,162
    Roseville, CA
    The heat pump and the air conditioner are the same device. The compressor is a high-voltage A/C motor, similar to what one would find in a home A/C. And the compressor runs off of the traction battery. I don't see any reason why the battery could not also be charging. You can have your phone plugged into its charger while you use the phone.
  4. a_gray_prius
    2,927
    783
    IL
    I haven't been able to have the car actuaallycharge while preconditioning - maybe I'm missing something?
