Current flow on highway
Discussion in 'Gen 2 Prius Main Forum' started by daniel, Apr 1, 2006.
  1. daniel
    14,487
    1,518
    Spokane, WA
    I just got the CAN-View installed (thanks Frank!) and on the way home noticed something interesting:
    When viewing the Prius's native Energy screen, at highway speed the arrow to and from the battery generally switches back and forth seveal times per minute. But with the CAN-View, I see that it actually switches back and forth (that is to say between charging and discharging) several times per second!!!. Apparently the MFD refreshes only once every few seconds, and displays the arrow as it happens to be at the moment it fetches its data for the refresh, and at highway speeds the arrow direction will be essentually random (useless) information.
    I don't know if this information serves any purpose, but I find it interesting.
    I'm looking forward to playing around with this thing a lot more.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    actually, its not really switching back and forth that much. its monitoring current flow and flow will hover at about 1-2 amps which means only nominal drain. at freeway speeds, the EV plays very little roles and so the need to charge is greatly reduced since only accessories will be draining the battery.
    if you watch CANVIEW, it will hover around 1-2 most of the time but will drop to larger negatives briefly if accelerating or starting up a grade. as soon as it hits a certain demand or charge level, then recharging begins and you will see a larger positive charge usally at least 10 amps give or take.
  3. daniel
    14,487
    1,518
    Spokane, WA
    Mine on the freeway was flickering rapidly between plus and minus. As you say, the amperages were in the very low single digits. But my point was the rapid flickering of the plus/minus sign, compared to the native Prius arrow display, which switches only once every few seconds. I conclude that at highway speeds the arrows are meaningless.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Clearly the native MFD averages a great deal. It also tends to report charging a bit more than discharging. The "glide" mode on the MFD is a fiction. You never get to neutral charge. I no longer try to "dead band" rather I try to accelerate such that I am changing at least the rate that I am discharging,,, 5-9 amps. Peering into the innards of this car is fun.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The analog needle reveals much, in fact. Instantaneous feedback
    from the current through the wires, no waiting. I could have [and
    in fact could swear I *have*, somewhere] detailed the story if
    one had asked... anyways, yes, that back-and-forth you see is by and
    large very minimal current flow. What this reflects is the hybrid
    system always seeking the 60% battery charge level, and while getting
    there it bobbles back and forth either drawing little bits of current
    out or sending charge back in. This is under *steady-state*, i.e.
    a completely unchanging demand.
    But demand always changes, doesn't it? Either your foot moves or
    cruise control makes a change. The first response to this comes
    from the battery, because it can be done instantaneously. Some time
    later, engine RPM and throttle are controlled to sort of "catch up"
    with the new situation. This gives you, among other things, a mild
    simulation of fuel enrichment, a la the classic accelerator pump.
    But there's no pump, and since the ICE wants to always run at a
    stoichiometric mix, fuel enrichment is studiously avoided. The
    closed-loop feedback time constant pretty much dictates that throttle
    and injector-time adjustments must be done *slowly* to keep the
    whole mess under control. I'm not exactly sure what happens after
    a *reduction* in demand, except that a big ol' pulse of charging
    current is sent to the battery. I theorize that it's additional
    load put on MG1 to slow the engine down, with its output sent to
    the battery because, well, there's no other place to send it.
    I'm pretty sure other people have written this up better than my
    attempt above. I can try to find some of those things if I haven't
    explained it well enough. I don't know if can-view is fast enough
    to show it, but if I'm on the highway and I bounce my foot up and
    down a little, I see substantial current spikes [~ 40A?] in both
    directions, while engine RPM [and thus power output] hardly changes
    at all over that very short timeframe.
    _H*
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I think that's a pretty good description Hobbit.
    I'll add that it is still like having the car new again with the CAN-View...you get so much more information about what's going on. The MG and inverter temps, battery and ICE temps even with moderate temps (low 70s here today) are all up significantly more than I would have anticipated.
    I saw my ICE temp up to 199, I saw MG1 temp up to 123 or so, then later MG1 Inverter at about that temp, but not while MG1 was that high, MG2 and it's inverter rarely get as high as MG1, but when I was using EVmode to accelerate and maintained a -40+ amp draw for a few seconds MG2 temp jumped up quite quickly.
    My battery temp usually was about 63 degrees when temps were in the 40s, and now it's in the 90s with temp near 70...what's it going to do when it's 100 out. Should I take out my radiator blocker since the ICE got up to 199 briefly going up a hill?
    I'd love to have a way to measure the internal resistance of the NiMH to see what temps it's working most efficiently at.
    I'm not well educated about electronics or engineering and although I did well in University Physics 1 I'm hardly an expert in that....but this is just too much fun.
    Not trying to sell this thing for Norm, but if you're gotten all the info you can out of the Energy and Consumption screens and want your Prius excitement rejuvinated get this CAN-View.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i think Frank mentioned that there is a 95ºC thermostat which would be ummm about...207ºF? so unless you are in that range for extended periods of time, your cooling fans dont even kick on. (they would usually only come on when not moving in any case)
    on the MFD, there is a "dead band" range where small changes are not going to be measured because there really is nothing to measure. also the delay in the MFD screen to changes in condition is actually quite long (not quite a second but far far from instaneous) so having it miss short charge cycles completely was not a surprise to me since all one has to do is punch the accelerator on flat ground and watch the arrows change after letting your foot off the gas. i have actually done this and had the mpg reading stay on 99.9 mpg. i dont really think there is a huge need to update the screen quicker. in fact, CANVIEW updates faster than i need it too.
    i don t think the Prius attempts to maintain a 60% SOC that tightly. iow, there is not going to be an attempt to charge unless there is a specific level of need. that need will cause a charge of min about 5-10 amps (this seems to be controlled by speed somewhat just as regen levels are).
    on the inverter temps, has anyone found out what kind of temps we should be trying to avoid yet??
    i havent seen 120º but one time when MOVING, but have had it spike to 130 if stopping for less than an hour and then taking off again. after a few minutes it will drop back down to the 110 range.
  8. daniel
    14,487
    1,518
    Spokane, WA
    Henry: I wonder if the MFD is averaging, or just taking a snapshot. I was guessing that on the current-flow arrows, it is taking a snapshot, making that particular item meaningless on highway driving.
    Hobbit: Yes, the CAN-View seems to respond as quickly as an analog needle, maybe faster. Your description makes sense. I'm going to try letting suddenly off the accelerator and watch for that current spike.
    I have the V2 without the OBD11 card. I just didn't think I needed to know MG and inverter temps. I mainly wanted to see amperage and engine temp. Aux battery voltage could be useful also sometimes.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    they are snapshots BUT, the CANVIEW uses a different scale than was is actually transmitted on the bus so you will be getting rounded off values for some. for instance, the RPM's are stated in 25 rpm increments, but the bus transmits them in something weird like 35 rpm increments. norm chose the 25 rpm increments because they are easier on the brain. that is why (i think) you will sometimes get very rapid toggling between values.
  10. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(efusco @ Apr 1 2006, 09:18 PM) [snapback]233646[/snapback]</div>
    if it was only briefly and only 199 don't take it out yet, when you first get your temp to 212F for more than a minute, that's the day I would call it summer and take it out. 199's not even hot yet and with Mobil1 in the cc your not hurting anything.
  11. Frank Hudon
    4,147
    yesterday coming home from the interior there are 3 hills you have to climb first one is 7% grade for 2 miles and I had MG1 inverter to 157F 67C by the time I made the top of the hill, holding 60 miles per hour. By the time I got to the next hill the car was cooler as it was snowing so I didn't get it over 50C and most of the time it was about 43-45C. I had taken the lips out for this trip because of the hills, the first of which is a 9% grade for about 1 1/2 miles. The top of the pass is 4400' and this trip I was in up to 4" of slush with the temp at freezing. I almost stopped and put the lips back in but I had another climb to 3800' after a decent to about 2000' but they are short steep climbs and didn't need to be stopping to pull them again. This summer I'm going to design an adjustable grill blocker and install it. Most likely one I can adjust from the inside of the car as I'm driving if required.
  12. hobbit
    4,089
    468
    Bahstahn
    Not sure how we diverted off to temperature ... but for whoever
    asked about the fans, they just come on when the normal coolant
    thermistor indicates somewhere around 100 degC. It's controlled
    by the ECM.
    _H*
