Current MPG readout question
Discussion in 'Gen 2 Prius Audio and Electronics' started by paulisme, Apr 17, 2004.
  1. paulisme
    paulisme New Member
    179
    Charleston, SC
    I've put about 50 miles on my Prius now, and I've got a question about the Current MPG reading on the display. While I'm driving, it jumps around all over the place; sometimes it says 21 MPG and other times it says 99 MPG. I know the screen refreshes every three seconds. Have I just not driven it enough for it to give an accurate MPG, or does it actually calcuate the mileage in three-second intervals? If it does the latter, I don't really see how that number would be meaningful at all.
  2. starla30
    starla30 New Member
    160
    Northampton MA, USA
    This is why it's the average MPG that people keep an eye on generally. I usually keep it on the consumption screen and only switch it over to the energy screen if I want to show off to newbies in my car or see if the engine is off.
    But yes, the current MPG changes dramatically if you are accelerating (5-30 usually) flat (30-70) or going downhill (99!)
  3. Brian
    Brian Member
    480
    Bakersfield
    In the consumption screen you will find the average.
  4. paulisme
    paulisme New Member
    179
    Charleston, SC
    Is there any way to make the consumption screen the default screen when I turn the car on?
  5. Brian
    Brian Member
    480
    Bakersfield
    I really don't think that there is a way to do that. Is there any technical person that can help him out?
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yes, make sure the consumption screen is the one that's on when you turn the car off.
  7. Brian
    Brian Member
    480
    Bakersfield
    I didn't think that would work. But i went and tried it and sure enough, it did.
