Curt Prime trailer hitch and Kendon fold-up trailer.
Discussion in 'Prime Accessories and Modifications' started by ghalperin, Sep 8, 2022.
  1. ghalperin
    ghalperin Junior Member
    Costa Mesa, CA
    2019 Prius Prime
    I wanted to be able to tow my Kendon trailer with my Prime, so I installed a Curt hitch. It was pretty straight forward. I did make a couple of 8mm locating pins to help with the install. I didn’t have a helper. 3F655BBA-228E-49D0-8EBF-8A909A773426.jpeg
    3C3FE348-12F1-4F14-9D7D-56466D22688B.jpeg F1E1EDAB-BB2B-4E88-89E0-103F8A22A08C.jpeg 75995558-BE1A-4CB4-9B98-8F86390DF533.jpeg
    I installed it along with the Curt wiring harness. It fits tight and high, out of the way.
    I purchased 3 different Curt ball mounts, before I got the right ball height combination. I ended up using the straight ball mount and the top of the ball ended up 18” from the ground. The trailer bed is 1/2” higher in the front. Almost level. I did a road test around town and down the freeway. With the trailer unloaded, I can barely tell it’s back there. The ball mount does rattle in the hitch, which is startling and annoying. I haven’t yet figured out what I’m going to do about that.
    bisco and pghyndman like this.
    49,371
    looks great, well done!(y)
