Custom PIDs for Torque Android app (ScanGauge alternative)
Discussion in 'Prius v Technical Discussion' started by usbseawolf2000, Oct 31, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    These the custom PIDs (gauges) are for the Android app called Torque ($5). It uses wireless connection (WiFi or Bluetooth) to connect to OBDII device. I am using Kiwi Bluetooth OBDII device by PLX ($99).
    These PIDs are based on the Gen3 Prius so they should work. Since I don't have Prius v to test, I need owner feedbacks.
    Using a PC or Mac, simply put the CSV file attached in ".torque/extendedpids" folder on your micro SD card. Keep in mind that ".torque" folder is hidden so set your explorer to show the hidden folders.
    Once the micro SD card is inserted and mounted in the phone, in Torque main screen, press Menu -> Settings -> Manage extra PIDs/Sensors -> Menu -> Add predefined set
    The following PIDs are available:
    • Regen Cooperation
    • Fuel Input
    • Fuel Input
    • Room Temp
    • Calculated Load
    • Vehicle Load
    • Atmosphere pressure
    • Engine coolant temperature
    • Injection volume (Cylinder 1) for 10 times
    • Injection duration for cylinder 1
    • State of Charge
    • Ambient Temperature
    • MG1 temperature
    • MG1 revolution
    • MG2 temperature
    • MG2 revolution
    • MG1 torque
    • MG2 torque
    • Inverter MG1 Temp
    • Inverter MG2 Temp
    • High voltage before it is boosted
    • High voltage after it is boosted
    • Boost converter temperature (upper)
    • Boost converter temperature (lower)
    • Inverter Coolant Temp
    • MG1 Carrier Frequency
    • MG2 Carrier Frequency
    • A/C consumption power
    • Battery Block Voltage -V01
    • Battery Block Voltage -V02
    • Battery Block Voltage -V03
    • Battery Block Voltage -V04
    • Battery Block Voltage -V05
    • Battery Block Voltage -V06
    • Battery Block Voltage -V07
    • Battery Block Voltage -V08
    • Battery Block Voltage -V09
    • Battery Block Voltage -V10
    • Battery Block Voltage -V11
    • Battery Block Voltage -V12
    • Battery Block Voltage -V13
    • Battery Block Voltage -V14
    • Traction Battery Temp
    • Temp of Batt TB1
    • Temp of Batt TB2
    • Temp of Batt TB3
    • Battery pack current
    • Internal Resistance R01
    • Internal Resistance R02
    • Internal Resistance R03
    • Internal Resistance R04
    • Internal Resistance R05
    • Internal Resistance R06
    • Internal Resistance R07
    • Internal Resistance R08
    • Internal Resistance R09
    • Internal Resistance R10
    • Internal Resistance R11
    • Internal Resistance R12
    • Internal Resistance R13
    • Internal Resistance R14
    • HV battery discharge control
    • HV battery charge control
    Torque running on HP TouchPad in my 2006.
    On an Android cell phone.
  2. msw48
    msw48 Junior Member
    I know this is a very old thread, but since it talks about PIDs, I'll try. I just bought a kiwi3 and I am wondering if the Torque Pro app will automatically give me trouble codes for the gen2 hybrid system or if I will need to download PIDs or what?
    kenoarto likes this.
