cut holes in battery casing for better airflow
Discussion in 'Gen 4 Prius Main Forum' started by DarioRAV4h19, May 17, 2022.
  1. DarioRAV4h19
    DarioRAV4h19 New Member
    NYC
    2019 Prius
    Good afternoon,
    I have a 2019 rav4 hybrid and I did a short research about maintenance of the traction battery. It turned out that excessive heat kills cells of the battery that are located in the center. That's reasonable. Did anybody here thought about cutting vent holes in metal casing and possibly installing a PC style fans in order to dissipate heat before cell degradation occurs?
    It seems like a lot but an ounce of prevention is better than a pound of cure ($5k battery).
    Prius hybrids has been for much longer than 5th get ravs that's why I am asking here.
    I would like to learn and pass on the knowledge about preventive maintenance of the traction battery so let me know about useful info and links to treads about this topic as well.
    thank you
    49,698
    that may create a dangerous situation and void your warranty.
    some here run the cooling fan on high, others have made changes inside the battery box.
    most have done nothing with no ill effects. heat is a bigger problem in the south.
    Pulse07 likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I wouldn't translate PRIUS to RAV4 - much bigger battery, and different in the mounting.
    TOYOTA has a sophisticated Temperature control algorithm running, both with the Traction Battery, the engine and the Inverter. I'd be inclined to trust TOYOTA.
    TOYOTA put a 10 year warranty on their batteries, so they must have confidence in them. They're also - in most cases, fine for the life of the car.
    Pulse07, Doug McC and Mambo Dave like this.
  4. DarioRAV4h19
    NYC
    2019 Prius
    thank you for replies
    Where can I educate myself about maintenance of traction battery?
  5. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    They sold me a Prius with their battery warranty in south Florida. I bet it gets 140 degrees in that car at times, perhaps more. I'm not concerned.
    Doug McC likes this.
  6. bisco
    49,698
    just search prius hybrid battery and other search terms on google
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,330
    6,007
    Columbia, SC
    Best place could be owners manual. If nothing of significance is in the manual, well..........
    If I had a 2019 Rav4 hybrid. I would just drive it and enjoy the ride.
    alanclarkeau and Doug McC like this.
  8. Doug McC
    Doug McC Senior Member
    1,009
    378
    Midwest
    2022 Prius
    For starters quit thinking that since it is in a hybrid vehicle it is “special”. Then learn everything you can about batteries in general (so you can decipher truth from fiction). Once you have that knowledge then go to sources that use the same battery technology (such as solar) and discern what you can from there.
    One final thought: assuming you paid going price for your vehicle, why do you not trust the engineers that designed it. I would think real hard before drilling holes in a decent car.
    alanclarkeau likes this.
  9. CooCooCaChoo
    CooCooCaChoo Senior Member
    905
    506
    Cow-lee-fornia
    2023 Prius
    Yeah, I wouldn't do it. If there is a problem with the battery later on, they could deny your warranty claim because of the mod, aka previous damage.
  10. bisco
    49,698
    it might also divert the cooling air in a way that would miss modules. it would have to be properly engineered
  11. Doug McC
    1,009
    378
    Midwest
    2022 Prius
    Perhaps the way it was done by some obscure company, maybe named “Toyota”?
  12. bisco
    49,698
    some have measured warmer modules in the middle, those are typically the ones that go first.
    and some have enhanced the cooling there. afaik, it did not involve drilling holes in the case
    does it help with longevity? idk
  13. alanclarkeau
    7,044
    7,584
    There is none required - it is likely to last the life of the car. As someone else mentioned - read both the Maintenance Schedule and the Owner's Manual.
