Cut plastic engine shield - oil changes
Discussion in 'Newbie Forum' started by Rob Kundert, Mar 5, 2014.
  1. Rob Kundert
    Rob Kundert Junior Member
    It appears that the access port held up by clips in the plastic shield under the engine compartment of my 2010 flipped down after a recent oil change, scooting along the roadway, like an air scoop for some miles. I thought the noise was from frozen slush that had lodged underneath until I looked and saw the problem.
    Has this ever happened to anyone before? ALSO, did this scoop up and deflect salt, slush and road grim that could cause problems down the road?
  2. Fore
    Fore Don't look back!
    494
    107
    This happen to me, had it fixed under warranty at the time. You should be able to re-attach it with tyraps or something else. Just do a search on PriusChat.
    52,390
    never heard of this one before, did you hit some road debris?
  4. Mike500
    Mike500 Senior Member
    2,593
    767
  5. Mendel Leisk
    41,901
    Who did the oil change?
