CV axle stuck in transmission?
Discussion in 'Generation 1 Prius Discussion' started by mifbifgiggle, May 25, 2021.
  1. mifbifgiggle
    mifbifgiggle Junior Member
    Long Island, NY
    2001 Prius
    Hey all, I've got my 2001 apart trying to replace the cv axle and I can't seem to get it out of the transmission. I've tried prying, spinning, hammering with a prybar, slow steady prying, and it doesn't seem to be coming out not matter what. It's moving slightly in and out, maybe 1/4 to 1/2 inch, and I don't know whether that is normal or not. I read that it's supposed to come out pretty easily so I'm stumped. Any advice? Do I just need to get a better angle and hit it harder? been trying for hours between last night and today.
    Thanks
  2. Josey
    Josey Active Member
    290
    110
    Virginia
    2003 Prius
    IT generally takes a hard and sharp whack. So, yeah - I'd say get a bigger hammer. Get something in there that will put on the outward pressure and whack it hard and fast.
    You might also see if your local AP store loans out one of these slide hammer tools & CV attachment:
    Edit: having said that, I've done quite a few of these, but never on my Prius. But I looked and it seems a pretty standard set up where it's retained by that little circlip at the end of the inner splines. That's all that holds it in, and it sits in a groove in the differential.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,200
    5,897
    Columbia, SC
    I had a Gen 2 axle that was being a bear a few months ago. I was able to use the axle itself as a slide hammer by removing the inner rubber boot and tightly clamping a vise grip plier near the edge of the outer housing. That allowed me to push the axle inward, then rapidly outward. The vice grip prevents the roller section from coming out of the housing. At the same time, when the roller section hits the vice grip, it acts like a slide hammer. Axle popped right out.
    Found this on the tube. Explains it very very well.
    Josey likes this.
  4. Cody89
    Cody89 New Member
    Ohio
    2001 Prius
    Can somebody help me? I'm replacing my 2001 prius cv axle and the new seal has a slightly smaller outside diameter, does it expand into place when I insert the cv axle??
  5. ChapmanF
    15,503
    That doesn't sound right.
