CV joints?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bisco, Apr 9, 2010.
  1. bisco
    49,481
    i'm wondering if a bad CV joint(s) could be making the low rumbling sound in my 04 with 70,000 miles? sound starts at low speed and changes with speed. thanks everyone!
  2. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    Bad CV joints usually make a clicking noise while turning. A low rumble would indicate a bad wheel bearing.
  3. richard schumacher
    7,663
    1,038
    United States
    In either case it's time for a trip to a mechanic. A wheel falling off or freezing up on the freeway can ruin your entire day.
  4. uart
    uart Senior Member
    4,215
    1,201
    Australia
    +1 for checking wheel bearings.
  5. bisco
    49,481
    thanks guys, i think the mechanic it is!:(
  6. bisco
    49,481
    jacked up the car today, rear wheels were smooth and quiet, fronts made a shushing noise, roters? disks? cvjoints/axles? both sides sounded the same. how can you tell if it's a bearing? mechanic?
  7. bisco
    49,481
    bad tire. (see: tire noise?)
