Cvt gearbox
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nashwan, Oct 22, 2018.
  1. Nashwan
    Nashwan New Member
    Sweden
    Business Edition
    Hello how much litter tacke the Cvt gearbox automatic in prius thanks?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    3.5quarts
    Nashwan and bisco like this.
    49,504
    thanks you
    Nashwan likes this.
  4. Mendel Leisk
    38,733
    The attachment is the Repair Manual instruction. Some tips:
    1. It's not spelled out, but you want the car to be roughly level when refilling.
    2. When adding the new fluid you just keep adding till it starts to come back out. Pour slowly from 3 liters on, to avoid spilling too much.
    3. Not in the instruction, but I've seen a Techical Service Bulletin that says to discard half used bottles, don't save them for next time. Similar to brake fluid.
    4. Stick with Toyota ATF WS fluid.
    5. I found a funnel with hose attachment (approx. 3' of hose) very simple and direct: run the hose down from above, or conversely from below, whatever works to snake it through.
  5. padroo
    padroo Senior Member
    2,763
    2,250
    Nashwan likes this.
  6. Nashwan
    Nashwan New Member
    Sweden
    Business Edition
    thank to all so kind regards
