CXRacing Coilovers
Discussion in 'Gen 3 Prius Accessories and Modifications' started by odonda8, Dec 3, 2017.
  1. odonda8
    odonda8 Junior Member
    US
    I cannot find any threads on them? Usually coilovers are over budget and normally just do springs and some koni yellows. These at $500 are tempting to try:
    ebay: 161577400224
    Anyone have feedback on these? Found some 350, IS and 3 series reviews that were good outside of the suspension snobs.
    This is also my first post so will show you my Prius. No worries if you hate it. :)
    Thanks,
    Dave
    orenji and RightOnTime like this.
  2. odonda8
    US
    Well, I gave in and ordered a set. I figure I can resell them if they are junk. The build quality looks good. I am a bit nervous about several loose barrings in the box...
    follow up question; can I expect to have issues front/rear alignment using factory hardware. Is a front camber kit or rear shim kit needed? Of course the lower the more severe the camber, how much variance should i expect though?
  3. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Love the blue of ur car but the teal wheels need to go
    odonda8 likes this.
  4. kodiakjoey
    kodiakjoey Junior Member
    concord nc
    Have you installed them ? Keep us posted on your results
  5. RightOnTime
    RightOnTime Senior Member
    754
    1,624
    183
    Kidnapped in OC, CA
    Our shop tried installing a set, unfortunately the front Coilovers did not match up.
    Customer had to return back the setup for a refund:(
    Burna J and orenji like this.
  6. odonda8
    US
    Same with me. They said mine must be an early 2011 because it still has 2010 parts?? Regardless they did send me a label and offered a full refund. I decided to just order TRD springs and sway bay. 1517450642971.jpg 1517450661647.jpg 1517450685090.jpg
  7. RightOnTime
    754
    1,624
    183
    Kidnapped in OC, CA
    2010-2015 Toyota Prius all have the same front Strut assembly. That is a bunch of bs they are giving you.
    iPhone ?
    sfv41901 and Burna J like this.
  8. -Jere
    -Jere Junior Member
    Akron oh
    That company sells junk piled on junk, don't buy eBay coilovers people!
    sfv41901 likes this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    That’s just an excuse. All gen3 Priis (2011-2015) have the same Strut assembly. If ur set on coils, try Tein street basic or street advance
    iPhone ?
  10. odonda8
    US
    Went the more OEM Prius Plus route with new shocks/struts, TRD springs and TRD sway. Much more pleasant to drive along with 17s. I honestly do not see a MPG change.
    sfv41901, m3pare, RMB and 2 others like this.
  11. PingPong
    PingPong Junior Member
    2014 Prius Plug-in
    CXRacing gets their coilovers made from BC. The IS300 guys have had good experiences with the CX coilovers.
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I’m sure their good.....they just don’t fit the Prius as listed. ‍
    iPhone ?
