Cylinder cut out
Discussion in 'Gen 3 Prius Technical Discussion' started by FireIsBorn, Jul 24, 2010.
  1. FireIsBorn
    FireIsBorn Junior Member
    Does the 3G Use it? Would a scangauge notice it?
    Thanks......
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    No the Prius doesn't drop cylinders to increase MPG the way some cars do, I think the 1.8L hybrid engine is efficient enough that it would not help, and would probably decrease efficiency, anyway.
    I don't know if that information would be on the data bus for the ScanGauge to read if you had a car with that feature, such as the Honda Accord V6. Honda sites might know, maybe they have an Xgauge for it.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Guess you could say that we have a 4-cyl cutout when we glide (no fuel consumption).
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    And yes, the Scan gauge notices that.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The correct term is cylinder deactivation. From the title and the first post, I thought the OP was talking about a cylinder that literally cut out and stopped firing.
    GM likes to use the buzzword "Active Fuel Management" for this technology, which is quite annoying as they usually use it when marketing monstrosity class SUVs.
  6. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    Just pull a spark plug wire :) or coil in this case
  7. bwilson4web
    15,507
    Yes, four at a time.
    Uh, yes, and the driver too.
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Cutting out 1 or 2 cylinders on a 4 cylinder engine would make for a pretty raggedy feeling engine.
    It would also be a smaller benefit when you have an eCVT and the engine management system we do.
    The purpose of cutting cylinders out on a V8 is to move the remaining cylinders to a higher efficiency region on the BSFC map, something a Prius already does a very good job of with the eCVT and engine management.
  9. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    That's for sure. I drove a 4-cylinder 3-speed automatic 1989 Ford Escort hatchback. Then it decided to become a 3-cylinder about 5 miles after getting a 65k service. It wasn't terrible as long as it had some throttle, but at or near idle it was pretty awful.
