D’oh! Left her running all day.
Discussion in 'Gen 3 Prius Main Forum' started by Webslog, Aug 2, 2019.
  1. Webslog
    Webslog Junior Member
    Stopped PQOTS (Priscilla, Queen of the Suburbs) in my work parking lot, hit Park, exited the car and walked into work.
    8 hours later, getting in the car, wondered why it was so cool inside.
    Prissy had been in Generator on Wheels mode for the entire day.
    An object lesson in “Park THEN Power.”
    Montgomery and Data Daedalus like this.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    How much fuel do you guess it burned in that time period?
  3. Webslog
    As best I can remember, 1 segment on the fuel gauge. It was hot (95 F) and I tend to run the AC on high.
  4. BZzap!
    1,607
    878
    I figure that’s about 1gallon. Hell, on a hot day, why not just leave it running?
  5. Mendel Leisk
    40,584
    Maybe skip Park, just hit Power?
    tvpierce, Pluggo, CR94 and 5 others like this.
  6. fuzzy1
    10,335
    You have plenty of company on this. Not me (at least for more than a couple minutes), but numerous others have fessed up to it.
    At least it wasn't in an enclosed parking garage. And for those who have pulled that trick, at least its ICE-on duty cycle is low, and the emission control system normally works quite well at scrubbing out CO.
    #6 fuzzy1, Aug 3, 2019
    Data Daedalus likes this.
  7. Threej
    Threej Member
    99
    99
    Portland, OR
    I *would* have done this a couple times. Except for the Prius blaring all its warnings and beeps at me whenever I try to remove the key from the vehicle when it's on. I'm a bit curious how that doesn't catch your attention?
    Mendel Leisk and fuzzy1 like this.
  8. fuzzy1
    10,335
    Spare key (on trips) or spouse's key (in jacket or purse) left inside vehicle?
    Absent those, the alarms have caught me a few times. But some parking areas could have enough ambient roar to miss that.
  9. Threej
    Threej Member
    99
    99
    Portland, OR
    Another case of I've *almost* done this, but then the Prius Lord comes after me with thunder and beeping when I try to lock the door.
  10. ChapmanF
    17,347
    "thunder and beeping"
  11. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    Ah the joys of push button start, if only there were an invention you were forced to actively remove from the car because your house key was attached
    tvpierce and Threej like this.
  12. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I tells ya… I really do appreciate the old-school twist key in our Prius c.
    I rent “modern” cars all the time but we haven’t yet owned a car with pushbutton start and I’m really not looking forward to it.
    Threej likes this.
  13. ASRDogman
    ASRDogman Senior Member
    7,243
    3,780
    You don't lock your car when you go into work?
    If I open the door, step out and press the lock switch it will lock then unlock.
    There is not mistake something didn't go the way I thought it should go.
    Then I notice I forget to turn the car off!
    davecook89t likes this.
  14. Mendel Leisk
    40,584
    Have to confess, to setting the parking brake (nothing else, not even Park) then trying to exit the vehicle witout shutdown, more than once.
    The alarms woke me up.
    There's something to be said for a system that uses physical key-in-slot, and it won't relinquish the key until everything is copacetic. Especially if the car key is on a ring of must-have other keys and fobs.
  15. fuzzy1
    10,335
    There are several places where I don't lock it at all, or don't lock it until after it is unloaded, so that motion is not fully ingrained.
    There are places where that "thunder and beeping" can be out-competed by local ambient noise or highway roar. That includes some workplaces around here.
    :whistle:
    The later half may work well for folks driving only automatic transmissions, but is much weaker for those of us whose other vehicles are still stick transmissions, which have no alarms or mechanics to force leaving them in a non-rolling state ...
    ... and where the family farm house and buildings are never locked, I have never even see a key for them. Vehicle keys there are never removed farther than necessary to hush any new-fangled key alarms.
    Threej likes this.
  16. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I thought the emission control systems were designed to deal with NOx (Oxides of Nitrogen) rather than with CO.
    I've read recently about people being killed by CO emissions from their non-hybrid "keyless" cars that were left running in the attached garage.
  17. fuzzy1
    10,335
    NOx and HCs and CO. When we had annual emissions testing here, the reports handed to us covered only HCs and CO, not NOx.
    But those are rare now. There used to be so much CO that is was a fairly reliable method of suicide. But not anymore, such attempts typically fail now, and folks have to shift to other methods.
  18. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    We sometime's attend grand kids sporting events in the winter when outside temp is around zero.
    I turn all electrical of but the fan on low. Lock the door with the key and go inside for a couple hours and come back to a warm and snow free car. Very small gas usage.
  19. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Very cool. I got poo poo'd here for leaving vehicle on ready with parking brakes on Park for 10 minutes going into stores. Hope you don't get that back lashing here.
  20. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    This only happened to me once, and it was brief, due to the fact that my car kept "beeping" at me as I left. When I tried to click it to stop beeping, it would just keep beeping. That forced me to go look inside...........and thats when I found out I left it on.
