D51 possibly causing thunderstorm-related issues?
Discussion in 'Generation 1 Prius Discussion' started by primuspaul, Jul 30, 2014.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I have had some thunderstorm-related issues happening with my 2002 Prius, such as warning lights and some systems shorting out after thunderstorms. It has an Optima Batteries YellowTop Dual-Purpose Battery, Group 51, 450 CCA (D51) battery installed with no restraining bracket. Is it possible this is causing the issues? Otherwise, car runs fine.
    51,937
    yeah you don't want that puppy rattling around in there while the lightning is flashing. can't you restrain it with a bungee cord and some foam packed around it?
  3. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    That is what I am planning to do. Actually, all of my issues happened during lightning storms while the car was parked and stationary. I was just wondering if the very fact that the battery was different from the OEM one could cause such issues.
    Any suggestions as to how to restrain it correctly and make it just as good as an OEM battery?
  4. Patrick Wong
    18,210
    6,510
    1. Check the tightness of the battery cables especially the negative cable where it is bolted to the body.
    2. An alternative battery bracket size is available, which was intended for use with the Panasonic 12V battery offered for sale by Toyota dealer parts departments as an upgrade to the original equipment size. You'll have to see whether that works with the Optima size you purchased.
    3. There is no inherent problem with using a 12V battery other than the original equipment size, as long as its Ah capacity equals or exceeds original equipment.
    4. What systems are "shorting out", and how do you know this is happening?
  5. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Had an electrical storm and got the red triangle + "Hybrid" warning. Reset code, car seemed okay. Another storm and the gateway ECU appears to have been fried.
  6. bisco
    51,937
    maybe you need one of those ground straps that drag on the ground.
  7. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Details?
  8. Wisco
    Wisco Member
    116
    If it were me, I'd try to pin down exactly what code is occurring. Either with a scantool, a smartphone with OBD wifi adapter, or at your local auto parts place if you can still drive it..
    Sceptic that I am, I would hesitate to assume the weather is causing this. Is that a known issue with our cars?
  9. bisco
    51,937
    some people, who get a static shock when getting in or out of their car will fasten a braided ground wire from the engine compartment down to the ground. i don't know anymore than that.
  10. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    The triangle following a storm really only happened once and has not happened since. The MFD issue did not come with a red triangle.
  11. Wisco
    Wisco Member
    116
    The two parallel threads on your car could have a single cause and it's a bit confusing to have both. I'm having trouble keeping track of what symptoms occurred when. For example was the red triangle after the storm the same occurrence as after Advance installed the battery mentioned in other thread? You also mention it being towed to the dealer, but not their conclusions about the problem..
    Totally up to you, but perhaps further discussion of your miscellaneous electrical issues should be on MPG display not getting information | PriusChat
    Chapman has helped me through electrical diagnosis before, and seems to be steering you in a good direction.
