Dallas Fort Worth mechanic needed for Generation I Prius
Discussion in 'Generation 1 Prius Discussion' started by dad's prius, Aug 29, 2011.
  1. dad's prius
    dad's prius New Member
    Arlington, TX
    2001 Prius
    I am looking for a mechanic who knows how to work on Generation I cars. I am receiving the orange triangle with check engine light and display shows a red car.
    I have cleaned the throttle plate as suggested earlier and that worked out for a little bit. Now even with a clean throttle plate, I continue to get the same triangle.
    Any help would be greatly appreciated.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    Does the car run? Can you get to an Autozone-Pep Boys-Carquest-O'Reilley and ask them to read the codes for you?
  3. dad's prius
    Arlington, TX
    2001 Prius
    The code that I get is P3120. But I can't figure out if it's the Map Sensor or the throttle body
  4. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
