Damaged parking sensors
Discussion in 'Gen 3 Prius Audio and Electronics' started by Justin Smyth, Dec 26, 2017.
  1. Justin Smyth
    Justin Smyth Junior Member
    Northern Irelans
    Active
    New user here - I hope I have posted in the correct subforum!
    Recently my car was reversed at low speed into another car (I wasn't driving and parking sensors were working at that time!). Since then the sensors have not been working. There is a different pitched beep for about 5 second then a solid tone for about 10 seconds then nothing.
    I think I can see which sensor was damaged. Can the individual sensor be replaced? I have installed a new set of parking sensors on a Skoda Fabia previously. If a sensor can be replaced could a keen amateur do it??
    Thanks
    iPhone ?
  2. Prodigyplace
    12,678
    11,830
    Central Virginia
    Elektroingenieur likes this.
  3. Elektroingenieur
    2,515
    3,287
    Three Touring
    Your profile says “2011 Prius,” so I’m assuming that your Prius was produced before the minor model change in December 2011, and that it is fitted with the Toyota Parking Aid (TPA) system offered as a dealer-installed accessory in Europe.
    Yes, I think so, though you may have to buy a set of four sensors, even if you only replace one. The Accessory Installation Manual documents for TPA Front (RHD) and TPA Rear are available for viewing in PDF at no charge on toyota-tech.eu. According to these manuals, a kit of four sensors has Toyota part number PZ464-00422-**, where ** is 00 for an unpainted black sensor, AB for one with primer only, or an abbreviation for the car’s three-character exterior paint color code (e.g., 040 for Super White II):
    Sensor Kit Part Number Exterior Paint Color Code
    1 PZ464-00422-00 Unpainted Black
    2 PZ464-00422-AB Primer Only
    3 PZ464-00422-BA 040
    4 PZ464-00422-BP 218
    5 PZ464-00422-CF 3P0
    6 PZ464-00422-CN 4W4
    7 PZ464-00422-DC 1G3
    8 PZ464-00422-DF 3R3
    9 PZ464-00422-HU 209
    10 PZ464-00422-MG 1F7
    11 PZ464-00422-MK 8R3
    12 PZ464-00422-MM 8S6
    13 PZ464-00422-MT 4T3
    14 PZ464-00422-MU 4T8
    15 PZ464-00422-MX 5A7
    16 PZ464-00422-MZ 6T7
    17 PZ464-00422-NE 070
    18 PZ464-00422-NF 6V5
    19 PZ464-00422-NG 9AH
    20 PZ464-00422-NH 9AK
    21 PZ464-00422-NI 8U5
    22 PZ464-00422-NJ 1G6
    23 PZ464-00422-NL 8V1
    24 PZ464-00422-NV 8T5
    I don’t see why not; see the instructions linked above.
  4. Justin Smyth
    Northern Irelans
    Active
    Thanks so much for your really helpful info I've had a quick look for the spares. Don't think I'll get a colour matched one so will probably just have to spray it.
    Thanks again
    iPhone ?
