Darn that low ground clearance
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Dec 27, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Today's PP math lesson: low clearance+high centering on a mound of ice=calling a tow truck. Me in Truckee, CA today.
    noonm and bisco like this.
    52,521
  3. Mendel Leisk
    42,041
    You're not lowered are you? Not that it's much to begin with.
  4. Leadfoot J. McCoalroller
    8,165
    7,669
    Pennsylvania
    2018 Prius c
    Where's an urn full of burnt coffee when you need it?
    Marine Ray likes this.
  5. Marine Ray
    1,139
    947
    Sparks, NV
    No, not lowered.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    darn.
    looks more of a problem than when i got my Gen3 stuck on wet grass.
    I had to use a tow strap wrapped around a tree pulling with my pathfinder.
    I still praise the Prius(s) as being the most reliable of any car in snow.
    But ice, any car is a non-winner in a battle.
    jerrymildred and Marine Ray like this.
  7. Tideland Prius
    16,630
    I scraped my bumper on a high curb today :cry:
    Data Daedalus and KCWhitney like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    No one would help you with a push:whistle:?
    If you’re passing through Truckee, are you on the west side of the pass now:)?
    Safe travels(y).
  9. fuzzy1
    10,603
    If it is truly high centered, human foot power is unlikely to push it free. It needs more force than that, or a lift up.
    Hmm. On comparatively hard ice, in a pinch, maybe jack it up, then push it forward off the jack? May repeat a few times until past the high spot?
    Raytheeagle likes this.
  10. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    If you follow the gradient of the ground and extrapolate, it ain’t that high centered ;).
    I’ve done my fair share of pushing in winter conditions:cool:.
    Good tip about the jack, but given the situation, that jack would be a tough one given the lack of ground clearance:(.
  11. fuzzy1
    10,603
    If that extrapolation told the whole story, then it wouldn't be high centered in the first place.
    When undercarriage crossmembers or protrusions embed themselves in ice or dense snow, resistance to horizontal motion becomes very high. It becomes the same as trying to push or pull a plow blade or anchor through the ground material. Even a couple bolt heads sunk into ice by the pressure can create a strong anchor.
    As have I. Human-powered pushing is for when poor tire traction is the primary issue.
    But when high centered, that tire traction loss is secondary. The primary problem is that much of the 'traction weight' is no longer on the tires, but is shifted to the hidden anchoring protrusions of the undercarriage digging into the high resistance frozen stuff.
  12. Marine Ray
    1,139
    947
    Sparks, NV
    Thanks for the idea. Considered that option and gave it a shot. She was pretty well high centered and the entire area in front was icey. Besides, gave me a chance to use the roadside assistance from my insurance company :)
    fuzzy1, dig4dirt and Raytheeagle like this.
  13. Marine Ray
    1,139
    947
    Sparks, NV
    My apologies. My photo does not do the situation justice. The passenger side was the high centered area. Yes, driver side doesn't look that bad.
    fuzzy1 and Raytheeagle like this.
  14. Marine Ray
    1,139
    947
    Sparks, NV
    PS - although not needed (because the tow truck hooked on both sides of the rear suspension), the tow eyelet is located with the jacking package in the charging cable storage area.
  15. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    Ray, what tires are on the car? If you have the original 3-seasons, yep, you're stuck. If good snow tires, it looks like a push forward--if there's room to go ahead--or a push back just enough to get it moving--would be worth a try.
    So-called all season tires are pretty much worthless on ice. The new all-weather tires with the winter certification are good on snow but again not much good on ice.
  16. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    see my thread. just added something.
  17. Marine Ray
    1,139
    947
    Sparks, NV
    The original Nanos. Fortunately the tow truck got me out and no under carriage damage.
  18. fuzzy1
    10,603
    He noted that the photo doesn't show the real problem, that is on the other side.
    This incident is a high-centering. When it is really high-centered, even great snow tires won't get it out. There simply isn't enough traction weight on the drive wheels, and too much anchoring weight embedding the undercarriage protrusions into the grounded ice.
