Dash board lights flickering
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by amnyce, Sep 21, 2017.
  1. amnyce
    amnyce Junior Member
    27
    Pennsylvania
    Hello,
    When I am driving my dash board lights will flicker and dim and brighten on their own.
    I checked the 12v battery, and it shouldn't be that - was 12.4v.
    Not sure if may be related, but there were also two times I was pressing the gas, but not really seeming to be able to increase my speed.
    I have NO warning lights ....
    2006 Prius - 160k - hybrid battery replaced about 10k miles ago.
    HELP!
  2. Osxarsam17
    Osxarsam17 New Member
    US
  3. amnyce
    27
    Pennsylvania
    Osxarsam17 - what was the issue?
  4. amnyce
    27
    Pennsylvania
    What was the issue?
  5. bisco
    52,393
    maybe a bad rheostat?
  6. Morey Pryer
    Morey Pryer Junior Member
    Amarillo
    Have you found a solution? My car is find the same thing
  7. Don402
    Don402 Member
    50
    29
    Omaha, NE
    I just started experiencing flickering of the dash and message center. Everything flickered off and on real quick a couple times.
  8. bisco
    52,393
    check the 12v to start with. after that, it gets difficult.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It would be REALLY nice if some of the people who reported this problem MORE THAN A YEAR AGO would come back and report the outcome for the benefit of others.
    Seems like the overall number of considerate people keeps going down all the time. :(
    There have been similar discussions in the past.
    The "usual suspect" is a main 12 V battery cable that is loose or corroded.
    The next suspect is the battery itself; there can be bad connections INSIDE the battery.
    After that, a lot of things could cause an intermittent loss of power.
