Dash cam compatibility?
Discussion in 'Prime Main Forum (2017-2022)' started by Diemaster, Aug 24, 2021.
  1. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    Does anyone know if these dash cams would work with the Prius Prime? The Avalon / Corolla models look like the best fit.
    Amazon.com: FITCAMX: TOYOTA
  2. JoeBlack
    JoeBlack Member
    108
    87
    Europe
    2021 Prius PHV
    It would most likely fit, but I would not really mess with a part that houses a camera for sign recognition and maybe more safety sensors.
    Right now, I am considering getting Viofo A129 Pro (with rear cam) - it is fitted on the glass, but picture quality is really nice, it's cheap, and you can hardwire it as well (plus it has GPS).
    Probably the only cam I would trust to harness Toyota systems is Comma, but that's another beast entirely.
    pghyndman likes this.
  3. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    Can any techs please chime in here? The module draws power for the front camera by using a harness to split the dynamic cruise control functionality which sounds very scary if you ask me, just wanted to know if any techs think that’s ok?
  4. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    I installed a Fitcamx 4K last year in less than 30 minutes and it has worked flawlessly. No wire routing or other hassles and looks like a factory installed option. Highly recommend it!
    Shaunius, dtsexpert and Doug McC like this.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    963
    631
    Monument, Colorado USA
    I don't know but my Z-Edge cost just $100 it also has a rear dash camera. It is wired but it's easy to gently lift up the car trim and tuck it in there. It connects wirelessly to a smart phone so you can see and download videos.
    Shaunius likes this.
  6. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    I've had the Fitcam X installed since last November and it's been perfect. No issues at all with the radar cruise control which I use just about every day. Can't recommend this camera enough!!
    Shaunius and pghyndman like this.
  7. Shaunius
    91
    24
    City of Angeles
    Did you get rear also and park assist
  8. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I installed a Fitcam X in my BMW 430i. I am very pleased with it. I did not install one in my Prime when I owned it. The only comment that I have is with the BMW, there was a small place to work and you need strong fingers to unplug and replug connectors. I did not purchase the rear cam.
