Dash Cam, is there a room behind the mirror
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Victorio Mo, Nov 13, 2024.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    120
    31
    Folsom, California
    I want to install camera behind rear view mirror off center on the right side, there are not too much room there, too many brain boxes. My Prius has all line navigation whistles.
    Do you know if this box with the grill do some emissions, can I block with with dash camera?
    marked with the red pointer. on the photo
    I 100% want to make in invisible for driver, this is a must .
    Anybody can share their stories how they install dash cam?
    Thanks
    Vic
  2. sylvaing
    sylvaing Senior Member
    1,200
    506
    I used a Fitcamx dashcam. Takes two minutes to install. It's basically just remove and set aside the mirror cover, disconnect a cable inside the mirror assembly and connect the dashcam in serie with the cable, put the new cover which has the dashcam built-in, that's it. And looks OEM.
  3. Victorio Mo
    Victorio Mo Member
    120
    31
    Folsom, California
  4. Victorio Mo
    Victorio Mo Member
    120
    31
    Folsom, California
    Wait ,I see that nothing fit Prius 2016 with all options. Need to check more.
