Dash Camera
Discussion in 'Prime Main Forum (2017-2022)' started by ClemsonSteve, Jun 4, 2018.
  1. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    So who has installed a dash cam in their Prime, and where did you hardwire it?
  2. citiprius
    citiprius Active Member
    241
    236
    51
    2018 Prius Prime
    I route the wires between the windshield and the roof, then to the passenger side behind the curtain SRS (pull out the SRS panel), then down along the windshield behind the SRS, then down behind the black rubber seal (next to side door hinge), then below the glove box, back to the center console and tuck the wire between the carpet and bottom of center console. You can plug in to either of the 12V plug. Or you can hardwire it behind the 12V plug at the back of the center console. Just pull out the panel from the back seat, then you can have the full access of the inside of the center console and connect to the back of the 12V plug.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Same thing I did on my wife's '07. And I'll do the same on the PiP once I find time to clean up my quickie installation.
  4. bb4srv
    bb4srv Active Member
    140
    106
    2018 Prius Prime
    Technology
    Hardwired it. Use the fuse add a circuit to wire it. There's 2 unused (no fuse attached) open fuse slots in the fusebox under the dash. One open spot is 12V constant - then on the next parallel fuse rail, another one open spot is switched 12v power. I forgot which is which, use a multimeter to test.
    Just make sure you plug the "hot" end to correct tap-a-fuse circuit side.
    Then just wire the cable along the driver side foot well, up the A pillar, behind the SRS airbag trim, then tuck it behind to top roofline.
  5. ltlurker
    ltlurker Member
    139
    28
    dc
    2020 Prius Prime
    has anyone used the 5v SOS panel to power the camera?
