Dash code lights keep coming on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ipat, Nov 16, 2018.
  1. Ipat
    Ipat New Member
    Temple, TX
    I have a 2006. It has had a problem with the brake lights, if it gets below 60 degrees they come on. I bungy cord the brake to keep it taught so that they don't come on. I forgot to one night and it got cold. The next morning the car was dead. My ex put in a new battery without knowing what he was doing. I ended up taking it to a mechanic where the wire harness and main relay were replaced. No the "triangle of death" light, oil pressure light and check engine light are on. The code reader will reset them but they come back on after a while. Any suggestions on what I can do?
    49,705
    welcome!
    unfortunately, you will need a prius aware reader and the online manual to troubleshoot.
    how many miles on her? she may not be worth fixing
    have you checked the oil?
  3. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    Mabe the brake light switch intermittently bad or maybe needs adjustment?
