Dash Light Problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Randyjaco, Oct 18, 2023.
  1. Randyjaco
    Randyjaco Junior Member
    Friendswood, TX
    I have a 2010 Prius with 180K miles. For some reason my dash lights are dimming. It has gotten to the point that it is difficult to see the dashboard in the daytime. The rheostat is turned up to max. What can I do to fix this?
    49,511
    maybe a bad rheostat? just a guess
  3. Randyjaco
    Friendswood, TX
    I guess it could be, but the rheostat seams to work throughout its range with no dead spots. Everything on the display works, and the dimness is uniform throughout the display.
    49,511
    try contacting matt at texas hybrid batteries. he rebuilds the combo meters, and may have an understanding of how the lights work
  5. Mendel Leisk
    38,738
    Dumb question, but: when turning the dash brightness dial up, you did push it past that first point of resistance, to full bright?
  6. Randyjaco
    Friendswood, TX
    Not until you said to. Eureka, there was light. Thank you. It took more force than I would have put on it, but it clicked on to a position that was obviously a full on and was considerably brighter than the rheostat controlled positions.
  7. Randyjaco
    Friendswood, TX
  8. Randyjaco
    Friendswood, TX
    Thanks to all that responded.
  9. Randyjaco
    Friendswood, TX
    Not until you said to. Eureka, there was light. Thank you very much. It was more force than I would have put on it, but it clicked to a full on position. That position is considerably brighter than the changeable mode.
    Thanks to all that responded (y)
  10. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Sounds like you drive around with the parking lights, or headlights on during the day.
    Dimming of the dashboard brightness is normal in that case, and yes, turning up the rheostat to Max brightness by clicking past the top setting will make the dashboard backlighting bright enough to see during the day.
