Dash Light Switch
Discussion in 'Prius v Technical Discussion' started by jerij, Jul 17, 2012.
  1. jerij
    jerij Junior Member
    Nashville
    Can someone please check.... My switch for my dash dimmer is located on the left side of the steering wheel on a panel just below the midpoint of the dash. It has 2 other switchs next to it, front light washer and the parking assist switch. Both these other 2 ILLUMINATE. The dash light rheostat does not.
    Is this correct? I find it somewhat of a paradox the switch one uses to adjust the dash light intensity, itself doesn't illuminate at night.....
    jerij
  2. jerij
    jerij Junior Member
    Nashville
  3. tanasit
    tanasit Member
    399
    60
    Philadelphia
    You are correct, the dimmer wheel has NO back-lit. I guess it feels differently from the others and you don't do the adjustment that often but it would be nice if it lit up too.
