dash light with red car and key
Discussion in 'Gen 2 Prius Main Forum' started by Steve David, Dec 30, 2009.
  1. Steve David
    Steve David New Member
    Lighthouse Point, Fl
    I never experienced the engine immobilizer light in the 2 years and 31,000 miles I've owned this Prius (08). It only flashes RED CAR with key thru it when the key is removed from the ignition and everything is off. The dealer (King in Deerfield Beach FLA says it normal. However, it's never done it before? I thought it was the Hybrid drive system warning light as they look similar.
    Any ideas? Thank you.
    Steve
  2. Patrick Wong
    18,200
    6,474
    Hi Steve,
    Your dealer is correct.
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Ditto what Patrick said.
    I forget exactly the sequence, but there are some occasions when you may not see it. However, it should flash under the scenario that you presented.
    Sometimes dealers give out erroneous information. But this time it was correct.
    Best wishes,
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Time for new glasses, Steve. That flashing light has always been there.
  5. Steve David
    Thanks, and you're right, just turning 56 and my eyes aren't what they use to be, neither is my brain, etc. etc.
    Steve
