Dash lights not coming on when headlights on
Discussion in 'Gen 3 Prius Main Forum' started by sktn77a, May 4, 2012.
  1. sktn77a
    sktn77a Member
    303
    NC
    My dashboard light used to dim when I turned my headlights on (normal behavior). Now they go off altogether. Dangerous, n'est-ce pas? Has anybody else had this problem? Is it a known issue with, for example, a fuse or relay? I plan to take it in to the dealer on Monday if I can't find something on this forum can can throw any light (pun) on, such as a switch setting that might have got bumped (just went out of warranty last month). :(
    Thanks
  2. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    There's a dimmer switch over to the left of the steering wheel. You slide it up and down to dim or brighten. Try that.
    Jmc15john and Lagabony like this.
  3. sktn77a
    sktn77a Member
    303
    NC
    Thanks. Yes, I thought about that. The car is at the airport (wife is out of town on a trip - it's her car and she called me from the airport this morning with her tale of woe). When she gets back that's the first thing I'll try.
    Fingers crossed!
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Likely what happened is the dimmer switch got turned all the way down.
    I just tried it in the car - if dimmer switch all way down with lights on, dash is blank. Turn lights off and dash comes on again.
    Roll the dimmer up (by left knee). should be fine.
  5. sktn77a
    sktn77a Member
    303
    NC
    I hope so! Will know tomorrow when the Missus gets home.
  6. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I had the same thing happen to my car after a trip to a detailer. Sure enough, they had the switch turned way down. I automatically went to checking fuses and, after finding everything in order and then figuring it was a switch, adjusted the brightness. On the plus side, I also found the SKS switch which made me go to the manual to figure out what it was actually used for.:rolleyes:
  7. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    And, once you spin it up to full brightness, give it a nudge past the detent and the display stays at full brightness all of the time, even when the headlights are on.
    Hope this was the problem. Let us know either way...
  8. sktn77a
    sktn77a Member
    303
    NC
    Yep, that was it - turned all the way down! How it got like that she doesn't know............
    :frusty:
  9. fuzzy1
    10,603
    But it is still your fault!
  10. El Dobro
    El Dobro A Member
    7,093
    3,271
    It may have been hit adjusting the mirror.
  11. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    If a tree falls in the forest, and there's no woman around, is it still the man's fault?
  12. sktn77a
    sktn77a Member
    303
    NC
    Of course it was my fault!
    :blah:
  13. WE0H
    WE0H Senior Member
    3,247
    528
    Could be one of those giant red headed woodpeckers :pound:
    Mike
