Dash lights out after replacing 12 V battery.
Discussion in 'Newbie Forum' started by Dano1956, Dec 4, 2016.
  1. Dano1956
    Dano1956 New Member
    Golden, MS
    Four Touring
    Greetings. I just replaced the 12 v battery on my 2007 Prius. Everything worked fine. I drove it around town for about 30 minutes. I restarted the engine. Everything looked good. 2 days later I started the engine but the dash lights were out. Computer lights were on. Engine wouldn't cut off unless the power button was held down. What's going on?
  2. Mendel Leisk
    38,750
    Maybe start by checking the 12 volt battery's voltage with a digital multi-meter.
    Did the last battery go suddenly? Just wondering, maybe there's a phantom drain on your batteries? Just a thought.
  3. Dano1956
    Dano1956 New Member
    Golden, MS
    Four Touring
    Yes. No problem then one day nothing except dash lights and the red triangle. It had been sitting for a couple weeks.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    This can happen on GM product if the battery was disconnected incorrectly. Requires (at times) a whole new dash because of a voltage spike. (GM does not have a fuse on the circuit board to prevent this)
    I would research any tech manuals to see if the Prius dash is protected by a fuse. If so, check that. I would also check my battery connections again. Always remove negative terminal first!
  5. Dano1956
    Dano1956 New Member
    Golden, MS
    Four Touring
    Thanks. I'll check.
  6. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    RCO likes this.
  7. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    RCO likes this.
