Dash lights suddenly not working at night
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dk_brookdale, Nov 18, 2025 at 10:50 AM.
  1. dk_brookdale
    dk_brookdale Junior Member
    65
    About two weeks ago I started noticing a problem. The problem is with lighting on the dashboard. The dash lights are not now lighting up properly at night. In the daytime when the headlights are turned on the dashlights remain lit no problem. But at night, when it is dark, the dashlights do not remain lit when the headlights are on. I understand that this might have something to do with the ambient light sensor. So I'm wondering of any of you who have seen this problem, how did you resolve the issue?
  2. ChapmanF
    18,044
    Usually when that happens to me, I have knocked the dash dimmer wheel a tiny bit with some parcel I was swinging in or out of the car, and turning the dimmer knob back up until the nighttime illumination reappears is how I resolve it.
    The only role the light sensor plays is that it keeps the illumination at day level when it's light out (even with the headlights on), but switches to night level (set by the dimmer knob) when it's dark out.
    dk_brookdale and BiomedO1 like this.
  3. BiomedO1
    BiomedO1 Senior Member
    3,454
    1,797
    SacTown, Ca
    Yes, it's strange that the dimmer switch will actually allow you to totally turn-off the dash lamps at night.o_O I had to pull over once and use my cell phone lamp to find the switch to crank it back up. It's not something you develop muscle memory, since it's one of those set it and forget it functions.:whistle:
    dk_brookdale likes this.
  4. ChapmanF
    18,044
    I think the illumination of the dash comes from sources of different kinds ... probably no incandescent light bulbs anymore in Prius v (though gen 2 had some), but some LEDs, and a vacuum-fluorescent meter display. Those kinds of sources don't all have a steady dimming curve down to zero, and things like temperature probably affect them too. Chances are it'd be hard to build a dimmer control reliably able to take them right down to minimum brightness but without any of them going out. If it worked in summer it might not in winter, or vice versa.
    I just replaced a dimmer in my dining room because the old one wasn't designed for LED light bulbs. The new one has a hidden little dial where you can adjust what its minimum output is, to keep it above where the LEDs just go out. Took me a few tries.
    BiomedO1 likes this.
  5. BiomedO1
    3,454
    1,797
    SacTown, Ca
    Once you get below 2 bars on my gen4, there's not illumination. Mine is usually set for 3 bars, so if it gets bumped by my knee - it's out.
