Dash lights wont turn on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Protricity, Jan 9, 2010.
  1. Protricity
    Protricity New Member
    Hey guys I'm having a problem with my dash lights not turning on at all when my 10 prius is running. The right side of the dash does not show anything except for the dash lights. Theis happened after my 12v battery discharged.
    Should I be checking fuses? The car drives fine otherwise.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Something easy to check, make sure the dimmer switch is not turned all the way down...
  3. PriusGuyfrom213
    PriusGuyfrom213 New Member
    L.A.
    This worked for me. Please like and subscribe if it helps.
    49,500
    whadidjado, disconnect the 12v?
  5. PriusGuyfrom213
    L.A.
    no not the battery really but the wire that connects to it from the dash. so everything else stays connected to the battery. check out the video. the hack helped me out.
