dash removal
Discussion in 'Prius c Accessories and Modifications' started by gas sipper, Jun 8, 2012.
  1. gas sipper
    gas sipper Junior Member
    31
    texas
    anyone have specs or diagram or instruction on how to take the dash pieces off to change them out and put back on? is it just pull off snap back on?
  2. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The dash removal is pretty complex task. To remove the upper or lower dash you will need to remove generally every sub-panel you see, just from my memory - center console, start-stop, side air vents, A pillars, side doors scuffs , side, inner defrosters and etc. panels.
    EDIT: sorry, I overlooked that question is inside prius C section.
    The easiest way to cover this job is to login to:
    Toyota Service Information
    and download the instructions from Repair manual - section INTERIOR PANELS / TRIM.
  3. gas sipper
    31
    texas
    i think i should of been a little more specific sorry. im referring to the two dash pieces above the glove box that have the swirl pattern design on them that are white or black depending on the model u have.
  4. gas sipper
    31
    texas
  5. gas sipper
    31
    texas
    the piece is black in this picture
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yank panel piece surrounding the radio.. then yank the a/c vent on the passenger side.. then yank the panel piece you speak of.
    easy peezy.
  7. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    Does anyone out there who has access to Toyota's system know how much those plastic pieces cost? I might like to swap mine out for black ones but I don't want to pay $15 or whatever it is just to look at what the prices are.
  8. SquallLHeart
    826
    247
    San Jose, CA
    TIS doesn't have pricing.. it has maintenance, TSBs, wiring, and repair manuals.
  9. secondspassed
    112
    26
    Corona, CA
    So how would one go about finding that information? Just going to a dealership and asking? I can't find any parts stores online that list the C.
  10. SquallLHeart
    826
    247
    San Jose, CA
    yea.. that's what i usually do when i need to price stuff out.
    but speaking with experience.... they're usually not cheap.
  11. gas sipper
    31
    texas
    the part numbers for the dash to change to black are....55479-52030-c0 and 55474-52030-c0 they are $150 and sme change from the dealer i found them online for like $90 together
    secondspassed likes this.
  12. cdinh24
    cdinh24 New Member
    I am also looking to change mine to the black color. Can you share where you found it online? Thanks, Wrabbit.
  13. gas sipper
    31
    texas
    i just googled the part number
  14. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    anybody done this yet? thinking about doing this... going to look much cleaner all black.
  15. B2FiNiTY
    979
    226
  16. Siva Ganesh
    Siva Ganesh Junior Member
    16
    United Kingdom
    Excel
    I know this post was a long time ago, but how easy peezy is it?! Do you just use a (plastic) flat screwdriver to prop the pieces out?
    Tbkilb01 likes this.
  17. SquallLHeart
    826
    247
    San Jose, CA
    i used my hands. i didn't use any tools.
