Dash toggle switch
Discussion in 'Gen 3 Prius Audio and Electronics' started by Raphael Muscarelle, Dec 9, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I've been trying to get toggle switches that will fit into factory panels of 2011 prius. With no luck. Switches I have found on eBay that say they fit just don't.
    I am trying to control low voltage usb led signs.
    Anyone know which toggle switch actually fit.
  2. ASRDogman
    ASRDogman Senior Member
    7,799
    3,978
    There are ones you can get that are round, and you drill a hole in the blank panels....
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,055
    780
    Virginia, USA
    I spent weeks researching this last year, made several purchases from eBay, and like you found -- nothing fits. I even tried ordering an OEM Toyota switch from Japan, but that was not the SPST that I was expecting.
    Bottom line, ASRDogman is correct. I ended up drilling a hole and using this switch:
    www.amazon.com/gp/product/B012IJ38S6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    If you find a switch that fits, please circle back and update this thread, please.
    #3 Johnny Cakes, Dec 15, 2019
    ASRDogman likes this.
  4. ASRDogman
    7,799
    3,978
    Thanks! :)
    When I first go my Prius, I bought a usb/audio jack extender that fit perfectly.
    I will search and see if it is still in my ebay history and can get the dimensions.
    I remember measuring and searching for one with the measurements. Some "said" they fit,
    but the measurements were different.
    Johnny Cakes and Georgina Rudkus like this.
  5. ASRDogman
    7,799
    3,978
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,494
    Taylors, SC
    Like Dogman, and of the mini rectangular switches will fit in a cutout. You can take the insert out and drill and cut it out or file the cutout to fit. If you make a mistake, you can buy replacement inserts.
    Even better, if you have a milling machine, you can mill it out.
    Any like these on Amazon will work.
    Just be sure that you get .187 or 3/16 inch connectors as 1/4 inch ones will not fit well and secure.
  7. ChapmanF
    18,522
    These switches aren't toggles, but they snap right into the panel cutouts, and you can get them with a lot of different markings. Air-On-Board push switches for 2008 Sequoia
    I used one for an AC power inverter installation:
    Earlier, I had found a different source, rockerswitchpros.com, that would let you send in a graphic file and they would send a switch with that exact graphic. But they didn't do this size switch, at least not back then. They had the size that fit the Gen 1 Prius though.
  8. travisjb
    travisjb Junior Member
    NC
    Thanks for sharing!
  9. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    Johnny Cakes likes this.
  10. Johnny Cakes
    1,055
    780
    Virginia, USA
    That is about the most OEM looking switch I have seen. Looking forward to your report regarding fit and also whether the power light is good or annoyingly bright.
    (someday I want to learn how they can sell what looks like a good switch and include shipping from China all for under four bucks. That's less that the delivery charge alone from the pizza place on my corner.)
  11. Raphael Muscarelle
    661
    222
    Those are cool
  12. Raphael Muscarelle
    661
    222
    Those are cool
  13. PaulthePriusAddict
    PaulthePriusAddict Junior Member
    26
    San jose
  14. ChapmanF
    18,522
    Do they let you send the graphic file to engrave? (I looked kind of quickly, but wasn't sure I saw yes or no.)
  15. PaulthePriusAddict
    26
    San jose
    Seems like you can send file to make but if you click, “Customs switches.” Then Small push switches. Then select choose from designs. I selected symbols series for the graphics I wanted.
    I was able to make the button I wanted! Haha
    Thought they didn’t make it for our buttons size. Oh I was wrong. Lol
  16. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
