Dashboard: Hybrid Systems Malfunction
Discussion in 'Prius v Technical Discussion' started by Ollie2017, Apr 18, 2019.
  1. Ollie2017
    Ollie2017 Junior Member
    Prius v 2017,
    Cleaned filter (battery cooling) and fan
    Hybrid battery measured at its terminal reads zero volt, safety switch engaged (orange)
    Is there a fuse or fusible link, or relay on the battery that needs to be turned on/replaced/connected?
    Thanks,
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    The fuse is in the orange handle (called a "service plug disconnect"), but usually the problem is the handle is not engaged completely. There are two movements required. See link.
    As a side note, there is a relay (power contactor) inside the battery which must engage as well under control of the battery ecu and the system ecus but the orange safety is usually not engaged properly.
    #2 rjparker, Apr 18, 2019
    Air_Boss and Raytheeagle like this.
  3. Ollie2017
    Followed the instruction, all is well thanks!
    Air_Boss likes this.
