Dashboard lift gate light is always on
Discussion in 'Prius c Main Forum' started by Jomo123, Apr 11, 2025.
  1. Jomo123
    Jomo123 Junior Member
    Upstate New York
    On my daughter's 2013 Prius C the lift gate trigger is causing the interior lights to stay on and also causes the dash light to show that the rear is open.
    Exactly how does the opening of the lift gate triggered everything? Where is this trigger? Can it be bypassed/repaired?
    Thanka,
    Jomo
    52,368
    just a wag, there would be wiring running from the hatch lock mechanism to an ecy somewhere to the dash light.
    likely a problem in the mechanism wiring but could be anywhere in the circuit.
    are you sure the hatch is closed tight, with no foreign objects in the lock area?
  3. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    The switch is built into the lock and latch mechanism at the bottom center of the hatch itself. (Kind of a smart design, they put basically every fiddly breakable thing into one unit so it almost doesn't matter what's wrong, you just replace that)
    Probably easiest to replace hers with a junkyard part. Otherwise...
    Good luck!
    Jomo123 likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,108
    2,150
    SacTown, Ca
    You can try spraying some WD40 into the latch assembly and working it, about a dozen times. Hopefully it'll start working again. If it doesn't work; you'll need to replace the assembly - no harm, no foul....
  5. Jomo123
    Upstate New York
    I tried what you said and it is working again. The question is for how long.
    Thnaks,
    Jomo
  6. BiomedO1
    4,108
    2,150
    SacTown, Ca
    IMHO; I wouldn't worry about it all that much. Apparently the mechanical assembly got torqued out of position, so the switch wasn't reading correctly. A little lube and working the unit got everything realigned; so it's working again.
    You now know what needs replacing, if the failure becomes permanent; so you'll be well prepared if it does fail.
    Good Luck....
