Dashboard lights are gone out
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Oct 6, 2017.
  1. Sid786
    Sid786 Active Member
    262
    148
    Cherry Hill, NJ
    Hey Guys,
    My dashboard light has completely gone out. So things like EV/Auto etc or Speed etc are not showing up. It is showing up but very very dark in the background. My HUD is still showing the speed.
    Do you know what caused this and how can I fix it.
  2. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
  3. Sid786
    262
    148
    Cherry Hill, NJ
    That was the first thing I tried and it didn't resolve it. Let me make sure that I am doing it right. So to set the light to Auto, I just manually revolved the knob on the left hand side of steering to align the headlight symbol to Auto. Is this correct?
  4. Sid786
    262
    148
    Cherry Hill, NJ
    Ah, found it. There is a set of buttons on the left knee side and my knee must have pressed it. These buttons are to set the dashboard lights on high or low.
  5. huskers
    huskers Senior Member
    2,546
    2,488
    Nebraska
    9 times out of 10 it is human error.
  6. Alan Winston
    Alan Winston Junior Member
    38
    30
    Seattle
    From decades of experience in tech fields, a very high percentage of human error is design error. An awful lot of user interface design invites operator error: the "human error" was by the designer.
    pilotgrrl and Mendel Leisk like this.
  7. jpep11
    jpep11 New Member
    22
    27
    New Hampshire
    Many of you are probably aware of this but you can also turn off the touchscreen entirely, which is kinda nice for night drives.
  8. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Nine months of owning this car and I’m still finding new buttons.
  9. Trollbait
    12,689
    A friendly safety awareness post.
    The dash lights are on the rear tail light fuse circuit. So if the dash suddenly goes dark, your tail lights may not be working either.
    pilotgrrl likes this.
  10. AnneLW
    AnneLW Member
    118
    95
    California desert
    This reminds me ...
    When my gen two hit about 160,000 miles, it suddenly kept losing power when the ac went on or climbing hill. Only sometimes. The dashboard battery indicator would show almost no charge, Three different dealerships couldn't figure it out. We just stopped using the ac and muddled along.
    At about 180,000 miles, the dashboard went dark for no reason. You could still drive the car, if you could correctly guess what gear you were in. It cost about $600 to repair.
    And-- voila!-- the power issue and ac problems were cured immediately! And then Toyota retroactively extended the warranty and reimbursed us our $600!
  11. Battery
    Battery New Member
    Los Angeles
    Was having trouble with the 12v battery but it turned out to be the ground wire was loose. Less than 12 hrs after the repair no lights on the dashboard. What was the issue and what did they repair for $600?
  12. Mendel Leisk
    41,924
    If that's the cause, yeah, that's design error. Anything that's unintuitive, error-prone, is a design fail.
  13. Battery
    Battery New Member
    Los Angeles
    I know about the dashboard light on the left at knee level. It doesn’t change anything for me.
  14. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
    Me too.:)
  15. Battery
    Battery New Member
    Los Angeles
    Well after sitting for 2 hours the dashboard lights up again!!!
